Re: Header leak issue....
[Re: moparguy1967]
#384450
07/23/09 05:15 PM
07/23/09 05:15 PM
Posts: 15,487 Florida
scratchnfotraction
I used a set of napa ultra seal header gasket and the high temp copper rtv on both sides of gasket and letting it hang on a wire for 15 mins to cure some instaled the gasket and header bolts just snuged up some,let sit over night,torqued the bolts down tight by hand no leaks for about 3 yrs till I pulled the engine this was a used set of headers and pitted on the flange and warped some I used a flat file and smoothed the flange flat around the port 68 Dart 318 A body 73 k-frame... I know what ya mean on tight fit and header leaks I also removed the studs in the heads for ease of installation good luck
[Re: moparguy1967]
#384451
07/23/09 07:08 PM
07/23/09 07:08 PM
Get a set of Remflex header gaskets.
#384452
07/23/09 07:49 PM
07/23/09 07:49 PM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
#384453
07/23/09 07:56 PM
07/23/09 07:56 PM
Posts: 329 Frederick, MD
moparguy1967
Frederick, MD
Since Im running a Magnum head with LA headers which gasket would you use? Is it better to match the head or the header? LA Magnum
[Re: GO_Fish]
#384456
07/23/09 10:35 PM
07/23/09 10:35 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Most header leaks are fault of the headers.
Remove the header and inspect the gasket. Find the leak and study the sealing surface of the header.
5/16" flanges also make this a losing battle.
[Re: DJVCuda]
#384457
07/24/09 12:09 AM
07/24/09 12:09 AM
Posts: 2,402 Wichita,KS
Blakcharger440
Wichita,KS
I purchased a set of the Remflex header gaskets before installing my set of headers and I am sure glad I did. It is a great product and gives me a piece of mind that I will not have any leaks there....it is a fairly thick gasket with great crush!
