Is it a problem to run a coil upside down? #383932
07/23/09 02:02 AM
07/23/09 02:02 AM
North Central USA (MN-WI area)
MuscleMopars Offline OP
Is it a problem to run a regular coil upside down?
Thanks,
Eric
email eric@musclemopars.com
715-426-HEMI (Shop)
612-669-CARS (Cell and Texts)
Go to my Moparts "Profile" to see my web site
Re: Is it a problem to run a coil upside down? [Re: MuscleMopars] #383933
07/23/09 08:17 AM
07/23/09 08:17 AM
scratchnfotraction Offline
I dont think so..I have seen them hanging from the wires swinging,laying on the intake getting heat,side ways on the fire wall,and sitting straight up,on junk over the yrs
mopar did mount them sideways and straight up
all I can say is try it and see
results could vary
Re: Is it a problem to run a coil upside down? [Re: MuscleMopars] #383934
07/23/09 08:22 AM
07/23/09 08:22 AM
There was a thread awhile back about oil filled vs epoxy filled coils & iirc that any position was OK if epoxy but OF ones lasted longer in a certain position, dont remember what though.
Re: Is it a problem to run a coil upside down? [Re: RapidRobert] #383935
07/23/09 08:48 AM
07/23/09 08:48 AM
NY usa
540challenger Offline
NY usa
The Oil filled can/might leak if not mounted in the vertical position.
Re: Is it a problem to run a coil upside down? [Re: 540challenger] #383936
07/23/09 08:59 AM
07/23/09 08:59 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Almost all coils were oil filled before epoxy existed and 90% were not mounted vertical.Eventually some leak but nothing lasts forever.
Re: Is it a problem to run a coil upside down? [Re: 62maxwgn] #383937
07/23/09 12:46 PM
07/23/09 12:46 PM
New Mexico
74Scamp Offline
74Scamp  Offline
New Mexico
IIRC, the original coil on my old 66 Dart was mounted on it's side. But then, the Dart was old, and so am I, so I can't be held accountable
Re: Is it a problem to run a coil upside down? [Re: 74Scamp] #383938
07/23/09 02:38 PM
07/23/09 02:38 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Check out all the old VW Beetles and you will see that the coils were mounted upside down. I never heard of any problems with them.
Re: Is it a problem to run a coil upside down? [Re: Snoopy] #383939
07/23/09 03:22 PM
07/23/09 03:22 PM
I've got a car where it was mounted on the firewall but the coil wire hits the hood when closed so when I mount it upside down everything fits better. Just never thought about the coil being upside down to be a problem until I did it. It seems OK. Thanks!
Thanks,
Eric
715-426-HEMI (Shop)
Re: Is it a problem to run a coil upside down? [Re: MuscleMopars] #383940
07/23/09 03:24 PM
07/23/09 03:24 PM
NY usa
NY usa
I guess the best thing to say is when you are able to mount the coil vertical do it but for the must part you will be fine if you don't.
