408 blown build #378341
07/17/09 08:51 PM
07/17/09 08:51 PM
s/e wisconsin
danbap Offline OP
danbap  Offline OP
s/e wisconsin
first time poster long time follower. I'm going to be building a forged 408 for a 94 Dakota using a magnum block. its going to be boosted one way or another i have a procharger D1SC that i had on my old 360 before i found the cracked block. or I'm going to put a turbo on it if i sell my supercharger. i think I'm going to go with K1 tech. crankshaft and rods unless there not right for this build they seem like a good piece and at a good price. i will be using a few parts i already have 4bbl m1, Hughes 2.02 heads, custom grind comp cam .550/.575 230/242 114, f&b 58x2 throttle body, i might have the heads ported if i have enough money at the time. will put arp studs through out engine. one thing I'm not sure about is pistons, i know forged but, I'm thinking about a compression ratio of about 9.5:1 and put about 15psi on top of that. but i cant seem to find pistons that will work.
thanks for any and all input.
thanks, dan.
Re: 408 blown build [Re: danbap] #378342
07/17/09 09:05 PM
07/17/09 09:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
First..... welcome to the jungle... in my opinion
your 9.5 compression is too high, I would go about
8.5 then boost that
Re: 408 blown build [Re: MR_P_BODY] #378343
07/17/09 09:11 PM
07/17/09 09:11 PM
s/e wisconsin
danbap Offline OP
danbap  Offline OP
s/e wisconsin
thanks for the welcome. the reason why i was going to go 9.5 so it wouldn't be gutless when not in boost.
94 cc dakota
Re: 408 blown build [Re: MR_P_BODY] #378344
07/17/09 09:30 PM
07/17/09 09:30 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
8.5 then boost that
A 408 motor with the small port heads you have should not be weak down low.
Re: 408 blown build [Re: Darryls-Demon] #378345
07/17/09 11:23 PM
07/17/09 11:23 PM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
15 psi and 9.5 is pretty much race gas territory unless you run E85 or meth injection. Unless you like pushing it on pumpgas.
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Re: 408 blown build [Re: CW25] #378346
07/18/09 01:25 PM
07/18/09 01:25 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
or maybe even a boost timing retarder.
Re: 408 blown build [Re: blownzoom440] #378347
07/18/09 06:10 PM
07/18/09 06:10 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Timing retarder would be needed either way. At 15psi I would want to be running race gas, E85 or have meth injection unless you like ash trays for pistons.
Re: 408 blown build [Re: DaytonaTurbo] #378348
07/18/09 08:01 PM
07/18/09 08:01 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
Any profesional piston manufacturer like Ross, JE, Diamond, so forth can make you up a custom boost friendly piston to handle the added loads.
Stick with 8.5 to 1....no problem with low end power.
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: 408 blown build [Re: instigator] #378349
07/19/09 05:27 PM
07/19/09 05:27 PM
s/e wisconsin
danbap Offline OP
danbap  Offline OP
s/e wisconsin
i will be running meth injection i had it on my last set up and i will be reusing it. my goal is to get my 94 dakota deep into the 11's do i dare say 10's with this set up. ive heard the lower compression was used to "hide" other faults is this true?
94 cc dakota
Re: 408 blown build [Re: danbap] #378350
07/19/09 06:02 PM
07/19/09 06:02 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Just wondering, but if you already broke one block under boost, why are you trying it again?
Magnum blocks aren't anything special compaired to the old stuff...
Re: 408 blown build [Re: dizuster] #378351
07/19/09 07:06 PM
07/19/09 07:06 PM
Dirty Dena, Maryland
dodge turbo Offline
dodge turbo  Offline
i run 8:1....i had ross make me pistons and then had them ceramic coated
It is far from gut less on the bottom end, that all depends on you cam and head selection, the advantage of 8:1 is that it cruises around like stock and gets decent mileage...
I had a N/A 8:1 360 in my truck for years with stock x-heads a mopar 508 purple shaft and the truck ran 12.9's- 13.0's all day
9:5-1 with 15psi you better be thinking some major top end reinforcement...or air to water intcooler on top of meth inject on a small block with c-16
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
Re: 408 blown build [Re: dodge turbo] #378352
07/19/09 09:16 PM
07/19/09 09:16 PM
West Central Wi.
1969 HEMI R-T Offline
West Central Wi.
Sounds like an interesting build. Are you selling the old blower set up?
Kevin
HEMI,S ARE FOREVER!!!
Re: 408 blown build [Re: 1969 HEMI R-T] #378353
07/19/09 10:37 PM
07/19/09 10:37 PM
s/e wisconsin
danbap Offline OP
danbap  Offline OP
s/e wisconsin
the block with the crack is it i dont think was caused because of me. its a long story but to wrap it up i bought an engine assembled(never do that again) and it wasn't what it was suppose to be i did blow the head gaskets and that when i found that out. so it was a stock cast crank, h beam rods and after market piston at about 9:1 compression. and the block is cracked between the head bolt and the water jackets.
and with that setup 2bbl intake and the 2.02 heads at 15psi it ran the best of 12.9 in the 1/4, i want to go much faster then that. i would love to see an 11.0 or even break 10's but that might be pushing it. not sure.
once i get the engine built and back in the truck im going to try and sell the D1SC and the bracket/tensioner setup to fund a turbo build. if its a remote mount or a regular manifold setup.
94 cc dakota
Re: 408 blown build [Re: danbap] #378354
07/20/09 12:03 AM
07/20/09 12:03 AM
West Central Wi.
West Central Wi.
can you PM me? I am in LaCrosse. might be interested in your set up.
Kevin
Re: 408 blown build [Re: 1969 HEMI R-T] #378355
07/21/09 09:02 AM
07/21/09 09:02 AM
s/e wisconsin
danbap Offline OP
danbap  Offline OP
s/e wisconsin
pm sent. ok 9.5 might be a little high if i dropped it to 9:1 would i still be ok with meth injection?
94 cc dakota
Re: 408 blown build [Re: danbap] #378356
07/21/09 11:15 AM
07/21/09 11:15 AM
that should be a fun ride. 8.5-9.0 C/R is real common on the boosted smallblocks we've done. done right they're very pump gas friendly, up to a point. 15 psi might be pushing it alittle.
Re: 408 blown build #378357
07/21/09 01:42 PM
07/21/09 01:42 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Welcome on,
Sounds like fun, Id talk to Dan at performance machine his handle is DRAM_PERF_ONLY
Great guy, carries K1 stuff, and is priced very well.
Kasey
