Fuel Pressure Dropping #377130
07/16/09 12:24 PM
07/16/09 12:24 PM
Frederick, MD
moparguy1967 Offline OP
Frederick, MD
For some reason my fuel pressure will slowly drop from 7psi to 3psi. When I start the car up cold, everthing is fine. But let it run for 5 mins, and the pressure will drop off. My car is a 71 Valiant with a stock 360 magnum converted to a carb. Im running an Alum cell with #8 line to the jegs billet filter into a jegs billet pump. From the pump to the reg is #8 line, then split to #6 to the carb. Im not running a return line to the cell. The fuel line does run about 3 inch at the exhaust at one point. But I can put my hand on it when the car is running. So I dont this it is getting the line hot. Any ideas.
Thanks, Bill
Re: Fuel Pressure Dropping [Re: moparguy1967] #377131
07/16/09 12:30 PM
07/16/09 12:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks, Bill
Check the voltage at the pump when this is occurring
Re: Fuel Pressure Dropping [Re: MR_P_BODY] #377132
07/16/09 12:32 PM
07/16/09 12:32 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Check the gauge if its the fluid filled type and is getting hot it wont work .
Re: Fuel Pressure Dropping [Re: cudabunch] #377133
07/16/09 12:37 PM
07/16/09 12:37 PM
Frederick, MD
Frederick, MD
I dont think it is the gauge. The car starts to lean out when the pressure drops.
Re: Fuel Pressure Dropping [Re: moparguy1967] #377134
07/16/09 01:17 PM
07/16/09 01:17 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Is your pump getting hot? I have the same problem. Although mine completely shut off on me.
Re: Fuel Pressure Dropping [Re: moparguy1967] #377135
07/16/09 01:28 PM
07/16/09 01:28 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Thanks, Bill
I have the same problem but on the nos side of the fuel system off the y block (I have not sprayed it yet)
Re: Fuel Pressure Dropping [Re: racerx] #377136
07/16/09 02:31 PM
07/16/09 02:31 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i have noticed when those liquid guages start acting weird, i will pry up on the rubber plunger on the guage and let some air in/out and it works fine again
