Sure grip = 15% torque loss? #375796
07/15/09 12:22 AM
07/15/09 12:22 AM
ILL
mark7171 Offline OP
mark7171  Offline OP
ILL
I was told that over a open differential, the sure grips/or posi type can take up to 15% of the turning torque away. Also up to a certain level an open differential will get better acceleration on the street. That the torque advantage can be 2:1 at times, from a foot braked start. Knowing converters can do stall tricks , this might be something possible in the differential?
Could a mild performance build benefit from the open rear end?
Is it that you just like 2 lines?
Re: Sure grip = 15% torque loss? [Re: mark7171] #375797
07/15/09 12:35 AM
07/15/09 12:35 AM
CT USA
N
Nick Mineau Offline
Nick Mineau  Offline
N
CT USA
i would say it has to do with the car. if you can launch @ full throttle with i peg leg and not spin then the possi wont help mabe only hurt. but most cars would cook the tire and a possi will duble the traction resulting i a much faster et.
Re: Sure grip = 15% torque loss? [Re: mark7171] #375798
07/15/09 12:40 AM
07/15/09 12:40 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Sorry I don't buy it.
All a limited slip unit is, is a set of spring loaded clutches, that try to hold the side gears to the carrier.
I don't see how it could cost any torque at all(other than the added mass the driveline has to turn).
For that matter, the sure grip unit actually does nothing, if the traction is the same on both wheels.
Of course there is probably some wizzy scientific explanationa as to why it is true.
Re: Sure grip = 15% torque loss? [Re: dave571] #375799
07/15/09 12:59 AM
07/15/09 12:59 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Well it would feel like a torq loss, you can have a car that'll spin one tire 20', then you put a suregrip on and it feels like a dog because you're actually getting some traction.
Re: Sure grip = 15% torque loss? [Re: mark7171] #375800
07/15/09 01:09 AM
07/15/09 01:09 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
No performance improvement from open diferential, unless your car is useing the wheel slipage as a way to multiply the tq because your tq converter is too tight. There is no tq multiplying though.
Back before my car had any musterd I swapped from a 2.94 open to a 2.94 sg both 7.25s and it felt slower with the SG but ets were quite a bit better and on the street I could finally get a jump on my wife in her maxima.
Re: Sure grip = 15% torque loss? [Re: dave571] #375801
07/15/09 01:29 AM
07/15/09 01:29 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Re: Sure grip = 15% torque loss? [Re: mark7171] #375802
07/15/09 02:09 AM
07/15/09 02:09 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
That energy would have to go somewhere and probably make a huge amount of heat, so I say no way...
Re: Sure grip = 15% torque loss? [Re: Lefty] #375803
07/15/09 10:24 AM
07/15/09 10:24 AM
Silver Springs, Florida
Charrlie_S Offline
Charrlie_S  Offline
I don't know for sure, but I think in a straight line, with both wheels haveing traction, there would be no power/torque loss. While turning, the clutches would slip, to allow one wheel to turn faster. This would generate heat, resulting in a power/torque loss.
Come to think about it, if the clutches were doing their job as designed (to transfer power to the wheel with the most traction), there would be heat generated, and this would equate to a power loss.
Charrlie_S
66 Cuda 170 nitrous
66 Valiant 225 nitrous
65 Valiant 170 turbo
64 Valiant driver
64 Valiant roller
Re: Sure grip = 15% torque loss? [Re: Charrlie_S] #375804
07/15/09 07:54 PM
07/15/09 07:54 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
Figure a well built 440 makes 500 foot pounds. 15% of that is 75 and there`s no way the axle is gonna create that kind of drag.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: Sure grip = 15% torque loss? [Re: gamagoat6x6] #375805
07/15/09 08:07 PM
07/15/09 08:07 PM
Manitoba, Canada
Manitoba, Canada
Like I said, it won't create an actual torq loss, but it can feel like one if you're using that one spinning tire to get engine RPM's up if you've got a tight torq converter. If you say had a converter that flash stalls to 4000-5000, you would not notice any torq difference between the two, other than never being able to hook with that peg legger.
Re: Sure grip = 15% torque loss? [Re: DaytonaTurbo] #375806
07/15/09 08:23 PM
07/15/09 08:23 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Seems to me, that there is a certain amount of drag in a limited slip when turning that is exacerbated when under power.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Sure grip = 15% torque loss? [Re: DaytonaTurbo] #375807
07/15/09 08:24 PM
07/15/09 08:24 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
only 1 way to prove it! if anyone is planning on putting an LSD into their axle, go to the dyno first, get a baseline.
then swap in the LSD and go re-dyno to see if there's a loss.
this would only work if the ONLY thing you changed was the diff, and did not do a gear change at the same time.
**Photobucket sucks**
Re: Sure grip = 15% torque loss? [Re: CJK440] #375808
07/15/09 08:33 PM
07/15/09 08:33 PM
Kirkland, Washington
Pacnorthcuda Offline
Ever driven a live axle go-kart? Those things are dogs at low speed with the wheel cranked. Everyone guickly learns to accelerate in the straightest line possible. Reason is simple, in a turn, the engine has to not only accelerate the mass, but over come the friction of the two rear tires having to turn different speeds.
Now in a limited slip, the axle can differentiate, which GREATLY helps, but there is friction present in the cones/clutches, generating heat, all made possible from consuming torque from the motor. So yes there is some truth to it....IF (big IF) the differnetial is being forced to differentiate (its in a turn).
Straight line? I wouldn't think there would be a difference, and of course if the peg-leg set begins to spin......
...and as far as a 15% torque loss? I don't believe it.
Re: Sure grip = 15% torque loss? [Re: mark7171] #375809
07/15/09 10:18 PM
07/15/09 10:18 PM
oklahoma
forphorty Online content
forphorty  Online Content
oklahoma
i have no earthly idea. but if an open open differential requires,say, 30 lb-ft to turn, an additional 15% is only 4.5 lb-ft more. almost insignificant.
Re: Sure grip = 15% torque loss? [Re: mark7171] #375810
07/15/09 10:38 PM
07/15/09 10:38 PM
Jacksonville, FL
burnt_o_matic Offline
Jacksonville, FL
Was that a circle track racer telling you this? There may be some truth to it in that situation.
Re: Sure grip = 15% torque loss? [Re: burnt_o_matic] #375811
07/15/09 11:11 PM
07/15/09 11:11 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Good catch! TURNING TORQUE! yes, I'd believe it if you had full traction on both tires, in a turn, when you're now forced to slip the clutches in the LSD.
maybe this is where a detroit true trac would be beneficial? no clutches, all gear LSD...acts like an open around a turn, until you gas it, then it acts like a locker, right?
I know if I have 1 wheel up in the air, the darn thing spins around and around like an open diff! scared me the first time I did that with it installed! I didn't fully understand how it worked yet!
Re: Sure grip = 15% torque loss? [Re: burnt_o_matic] #375812
07/16/09 07:23 AM
07/16/09 07:23 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
If it was he won't have to worry about it long using a SG on the circle track.
Re: Sure grip = 15% torque loss? [Re: 70Cuda383] #375813
07/16/09 07:47 AM
07/16/09 07:47 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
A chassis dyno simulates a straight line run. If you could find a dyno that had rollers that were different diameters I think you'd see more loss with an LS rear than an open.
Re: Sure grip = 15% torque loss? [Re: MoparforLife] #375814
07/16/09 11:26 AM
07/16/09 11:26 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
don't the nascar guys use LSDs? I've never seen one do the one tire fryer when they do their celebratory donuts at the end of the race, and theres always 2 equal, long black marks. although I've wondered that before myself--how can they use a LSD when they're making left hand turns ALL DAY
Re: Sure grip = 15% torque loss? [Re: 70Cuda383] #375815
07/16/09 11:54 AM
07/16/09 11:54 AM
IMO, having a LSD has much more benefits than it has negatives. They may take more power to make a turn but only if power is being applied and under normal cruise conditions, they are slipping pretty easily.
