Re: Sure grip = 15% torque loss?
[Re: mark7171]
#375798
07/15/09 12:40 AM
07/15/09 12:40 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
Sorry I don't buy it. All a limited slip unit is, is a set of spring loaded clutches, that try to hold the side gears to the carrier. I don't see how it could cost any torque at all(other than the added mass the driveline has to turn). For that matter, the sure grip unit actually does nothing, if the traction is the same on both wheels. Of course there is probably some wizzy scientific explanationa as to why it is true.
[Re: mark7171]
#375800
07/15/09 01:09 AM
07/15/09 01:09 AM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
No performance improvement from open diferential, unless your car is useing the wheel slipage as a way to multiply the tq because your tq converter is too tight. There is no tq multiplying though.
Back before my car had any musterd I swapped from a 2.94 open to a 2.94 sg both 7.25s and it felt slower with the SG but ets were quite a bit better and on the street I could finally get a jump on my wife in her maxima.
[Re: dave571]
#375801
07/15/09 01:29 AM
07/15/09 01:29 AM
Posts: 10,232 Someplace you aren't
SomeCarGuy
[Re: mark7171]
#375802
07/15/09 02:09 AM
07/15/09 02:09 AM
Posts: 6,516 Santa Cruz, California
Lefty
the sure grips/or posi type can take up to 15% of the turning torque away.
That energy would have to go somewhere and probably make a huge amount of heat, so I say no way...
[Re: Lefty]
#375803
07/15/09 10:24 AM
07/15/09 10:24 AM
Posts: 63 Silver Springs, Florida
Charrlie_S
I don't know for sure, but I think in a straight line, with both wheels haveing traction, there would be no power/torque loss. While turning, the clutches would slip, to allow one wheel to turn faster. This would generate heat, resulting in a power/torque loss.
Come to think about it, if the clutches were doing their job as designed (to transfer power to the wheel with the most traction), there would be heat generated, and this would equate to a power loss.
Charrlie_S 66 Cuda 170 nitrous 66 Valiant 225 nitrous 65 Valiant 170 turbo 64 Valiant driver 64 Valiant roller
[Re: DaytonaTurbo]
#375806
07/15/09 08:23 PM
07/15/09 08:23 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Seems to me, that there is a certain amount of drag in a limited slip when turning that is exacerbated when under power.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: DaytonaTurbo]
#375807
07/15/09 08:24 PM
07/15/09 08:24 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
only 1 way to prove it! if anyone is planning on putting an LSD into their axle, go to the dyno first, get a baseline.
then swap in the LSD and go re-dyno to see if there's a loss.
this would only work if the ONLY thing you changed was the diff, and did not do a gear change at the same time.
**Photobucket sucks**
[Re: CJK440]
#375808
07/15/09 08:33 PM
07/15/09 08:33 PM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
Ever driven a live axle go-kart? Those things are dogs at low speed with the wheel cranked. Everyone guickly learns to accelerate in the straightest line possible. Reason is simple, in a turn, the engine has to not only accelerate the mass, but over come the friction of the two rear tires having to turn different speeds. Now in a limited slip, the axle can differentiate, which GREATLY helps, but there is friction present in the cones/clutches, generating heat, all made possible from consuming torque from the motor. So yes there is some truth to it....IF (big IF) the differnetial is being forced to differentiate (its in a turn). Straight line? I wouldn't think there would be a difference, and of course if the peg-leg set begins to spin......
...and as far as a 15% torque loss? I don't believe it.
[Re: mark7171]
#375810
07/15/09 10:38 PM
07/15/09 10:38 PM
Posts: 93 Jacksonville, FL
burnt_o_matic
Jacksonville, FL
Was that a circle track racer telling you this? There may be some truth to it in that situation.
[Re: burnt_o_matic]
#375811
07/15/09 11:11 PM
07/15/09 11:11 PM
70Cuda383
Marysville, O-H-I-O
Good catch! TURNING TORQUE! yes, I'd believe it if you had full traction on both tires, in a turn, when you're now forced to slip the clutches in the LSD.
maybe this is where a detroit true trac would be beneficial? no clutches, all gear LSD...acts like an open around a turn, until you gas it, then it acts like a locker, right?
I know if I have 1 wheel up in the air, the darn thing spins around and around like an open diff! scared me the first time I did that with it installed! I didn't fully understand how it worked yet!
[Re: burnt_o_matic]
#375812
07/16/09 07:23 AM
07/16/09 07:23 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
If it was he won't have to worry about it long using a SG on the circle track.
[Re: 70Cuda383]
#375815
07/16/09 11:54 AM
07/16/09 11:54 AM
IMO, having a LSD has much more benefits than it has negatives. They may take more power to make a turn but only if power is being applied and under normal cruise conditions, they are slipping pretty easily.
