Steering Center Link Binds on Oil Pan #374543
07/13/09 10:53 PM
07/13/09 10:53 PM
Virginia
MACDiesel Offline OP
Virginia
I have a '67 Belvedere 440/4-speed. I just put a Milodon 31580 road racing oil pan on and the center link binds on the right side. I didn't want to mod the pan so I searched for alternatives.
I called just about everywhere. No one had a different solution. Everybody is modding their oil pans. Mopar doesn't even reproduce center links. Finally I called Firm Feel and ordered their fast ratio pitman and idler arms. They're 1.5" longer than stock and should fix my binding issue. Their only draw back is they don't work with some headers.
Check them out: http://firmfeel.com/fastrati.htm
I still want to find a solution with the center link that doesn't involve swapping the arms. Someone has to make it or I'll figure out a way to have them made so they can be bought for around $300-350.
Anybody got ideas?
Ray at CAP and Dick at Firm Feel deserve a big thanks. Those guys are awesome. It's guys like that, that keep this hobby alive! Next time I need suspension or steering parts I'm calling Firm Feel and CAP!
-1967 Belvedere II 440/4speed
Re: Steering Center Link Binds on Oil Pan [Re: MACDiesel] #374544
07/14/09 12:15 AM
07/14/09 12:15 AM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
Probably a issue with the idler arm mount being out of whack and needs the hole slotted and a washer welded in to lower the idler arm.
Re: Steering Center Link Binds on Oil Pan [Re: MACDiesel] #374545
07/14/09 12:47 AM
07/14/09 12:47 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Do the 66 and 67 B-bodies have stud mounted idlers. From the 444 source oil pan list it seem the the big block 66-67 B-bodies take the same 383 pan as 383 68-71 B-bodies.
The Milodon pan might not have the same fit for a 66/67 idler. I'm even surprised they offer a Big Block road race pan at all. It's really tough to fit road race pan in Mopars because of the surrounding K-member and rear steering linkage. Did others say it just didn't fit 66/67 B-bodies or are they having that problem with all body types.
In my opinion you should run the 70-72 B-body K-member if you are interested in handling. The 66/67 stud mounted idler flexes. The unique 66-67 idler will or allready has been discontinued. The wide 66-69 style sway bar limits the backspace rims you run in the front and they hang down a little low and bushing straps got beat up.
If you are will to pay 300 for some custom centerlink with a good chance of someone botching up the geometry. Why not spend $75 to have some notch and weld you Milodon pan.
Re: Steering Center Link Binds on Oil Pan [Re: autoxcuda] #374546
07/14/09 02:35 PM
07/14/09 02:35 PM
Virginia
Virginia
No, it's not stud mounted.
Surprisingly, the pan fit great with TONS of clearance between it and the K-member. Ground clearance with 7 qt capacity was the goal with choosing that pan. Milodon did great.
Tell me more about that 70-72 b-body k member. My goal in the end is handling but of course I don't have $5k to throw at a tubular piece. Will the 70-72 just bolt up? What else will I need? Will it move the motor, affecting the trans crossmember?
As far as modding the pan, I'm just picky that way. I've heard that from a lot of people and you along with all of them are probably right. I know there is nothing wrong with modding the pan. Hell, thats how Speed O Motive does it and they're pretty damn good at what they do. I just don't want to do it.
Re: Steering Center Link Binds on Oil Pan [Re: MACDiesel] #374547
07/15/09 12:49 AM
07/15/09 12:49 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Beware,
the 71 and up (newer) K member is totally wrong, the steering box mounts at a different angle, Like an E body.
68-70 should be what you are looking for., but I dont think there is any differece between 67 and 68 as far as engine location.
It also sounds like you need a C body style notch in the oil pan. I think that is the 187 pan..
Re: Steering Center Link Binds on Oil Pan [Re: sthemi] #374548
07/15/09 01:18 AM
07/15/09 01:18 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I have dealt with the same thing this summer.
I had a 7 quart low hanging pan- hated it. I didn't like the ground clearance since I drive all the time and do no drag racing with the car. I beat the crap out of the right side, JB welded it up for extra strength and called it good. Then I got mad about the clearnace and out it came.
In went the road race pan you have. I have a 69 383 RR. Pan is KILLER. fits real well all the way around. EXCEPT the same exact hitting you have and the same exact problem as the low hanging pan. Can't beat on this work of art- way too many complex bends, baffles etc to chance it.
I noted how it hit, and in reality it only hits at full travel and really doesn't increase the turning radius. SO I lived with it.
I noticed when I changed the pan that my idler has no place for a cotter pin. Disturbing, but I haven't decided on changing it or not. Considered that might be part of the hitting problem.
Then I got an alignment. The toe was off. THe adjustment made the clearance better, but still kisses slightly.
That is where I'm at right now. The pan is a really great piece, for those that haven't seen one I would say it is worth checking out. If you aren't running an external oil line it is a super good option. You could drill it for one I would think if you wanted to run it. It tucks AWESOME. Also has a place for an oil temp sender to screw into.
I want my fair share
Re: Steering Center Link Binds on Oil Pan [Re: MACDiesel] #374549
07/15/09 01:24 AM
07/15/09 01:24 AM
SomeCarGuy Offline
SomeCarGuy  Offline
I changed another 69 RR to the 70 up K bar. Not a hard change at all. Nothing but the K bar and the sway bar is changed and maybe the LCA's.
Much better options on sway bars since it has the pass through design.
Re: Steering Center Link Binds on Oil Pan [Re: SomeCarGuy] #374550
07/15/09 03:46 AM
07/15/09 03:46 AM
Virginia
Virginia
I knew I wasn't alone on this.
Did you check out the fast ratio arms. They make so much other cool stuff, I'll probably end up spending a lot of $ on that company. Sure they won't mind.
Try a locking flange nut. The ones on my engine mounts are 42 years old and they're still locking up tight.
This pan is TRICK!
So the 70 K member is a straight bolt up deal? My car doesn't even have sway bars front or rear. That's something I'm looking into. There're two things my car won't do: turn and stop!
Re: Steering Center Link Binds on Oil Pan [Re: MACDiesel] #374551
07/15/09 10:55 AM
07/15/09 10:55 AM
SomeCarGuy Offline
SomeCarGuy  Offline
I haven't looked into any fast ratio parts as I have manual steering. I don't really need the killer pan but I had to replace a crappy stocker and wanted to upgrade the pan. I had the drag pan for another project so...
I might put one of those nuts on there, but I might just change the idler. I figure it is a CHEAP part if the maker didn't bother to drill it for a cotter.
The K bar bolts right in like your current one does, 4 large bolts. Somebody might chime in and tell you if the LCA's have a different tab location on the 70-up for the sway bar.
Watch for the welds to be busted around the LCA "tubes" in the K bar, will usually need weled up. Would be easy to do with it out on the ground. It would be worth checking your current K bar if you end up not changing it out as the almost always are busted out.
Re: Steering Center Link Binds on Oil Pan [Re: SomeCarGuy] #374552
07/15/09 12:17 PM
07/15/09 12:17 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The K bar bolts right in like your current one does, 4 large bolts. Somebody might chime in and tell you if the LCA's have a different tab location on the 70-up for the sway bar. ..
The 70-72 B/E LCA's have sway bar tabs in the middle of them. The 66-69 LCA's have sway bar tabs on the end.
Hotchkis now makes 70-72 B/E LCA tabs you can weld into your non sway bar lower control arm. Might be easier for you since in live in HI and parts must be scarce.
I know the E-body 70-74 and 71-72 B-body K-frames have a different steering box angle. I don't think it's an issue with stock exhaust. But has anyone had a steering geometry related issue from the swap? I have heard TTI having an issue with swapped K-members since there stuff is tucked up so close.
If you K-member doesn't have a stud mounted idler and the idler is bolted to the Kmember sandwiched between two pieces of flat metal on top and on bottom, than there is nothing gained there.
Only gain would be the shorter 70 style sway bar. That allows for more front tire backspacing than 4.75 or so.
Lefty has a 67 B-body Coronet setup for handling. Wonder what his thoughts are?
Re: Steering Center Link Binds on Oil Pan [Re: autoxcuda] #374553
07/15/09 05:01 PM
07/15/09 05:01 PM
Virginia
Virginia
If only I had an extra $5k laying around... all my problems could be solved.
Re: Steering Center Link Binds on Oil Pan [Re: autoxcuda] #374554
07/16/09 02:12 PM
07/16/09 02:12 PM
Virginia
Virginia
My bad, the idler arm is stub mounted. I was mistaken.
So is that and the narrow sway bar the only advantage to the later k member?
Re: Steering Center Link Binds on Oil Pan [Re: MACDiesel] #374555
07/16/09 02:14 PM
07/16/09 02:14 PM
SomeCarGuy Offline
SomeCarGuy  Offline
If that is the case I think you may as well swap to the 70 K and kill two birds...
Re: Steering Center Link Binds on Oil Pan [Re: SomeCarGuy] #374556
07/17/09 01:55 AM
07/17/09 01:55 AM
Virginia
Virginia
So I got my pitman and idler arms today. They sent me an Idler arm for the '68 and up cars. (pictured center) Of course they mount to the k-member differently. Mine uses a ball joint style mount. (pictured right)
I'm really not sure what I'm going to do. I'll call Dick at Firm Feel tomorrow and see what he says. Does anyone know if I can have the ball joint mount of the old one fitted to the new one? It looks close to the same size. I don't have the time or money right now to swap the k member.
Theold pitman arm isn't pictured because its still on the car. I forgot I needed to buy a pitman arm puller.
Re: Steering Center Link Binds on Oil Pan [Re: MACDiesel] #374557
07/17/09 03:04 AM
07/17/09 03:04 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
That's what I call a stud mounted idler. There is just a tapered hole in your K-member that the idler goes into. The 67 and down A-bodies are like that. Those inherently have less support (flex). That middle idler is a thru hole type that has a support on the bottom and top.
I bet that 66/67 idler is not easy to get (I bet discontinued by Moog). That's why you got that 68 up unit in the center.
And that is one of the main reasons I suggested in the post prior going to the 70 B-body K-member.
Re: Steering Center Link Binds on Oil Pan [Re: autoxcuda] #374558
07/17/09 03:19 AM
07/17/09 03:19 AM
Virginia
Virginia
Yeah that is now in the to-do list for the car. Is there anything I can do in the meantime. Maybe open the small end of that tapered hole to 9/16" and bolt the new one on. It should be just about as strong as the old stud. And if it doesn't work the hole will still be tapered, so I could just reinstall the old one.
Re: Steering Center Link Binds on Oil Pan [Re: MACDiesel] #374559
07/17/09 04:16 AM
07/17/09 04:16 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Now that I look at the picture I see why he sent you that thru bolt idler. That is the long idler (actually listed optional on the FF site) that goes with the long pitman arm. It's actually a 71 C -body idler. The original E-bodies with the Fast Ratio option steering had the standard shorter idler on one side. Firm Feel offers to upgrade/correct the situation with the C-body idler. But that only worked on thru bolt idler aplications.
Idler for your car on www.rockauto.com MOOG Part # K779 Frt Strg; Problem Solver $48.79
You could run a 66/67 idler on one side. BUT, I think you are running the longer arm/fast ratio idler arm for the oil pan clearence issues also??
This is ugly... but you could just run a bolt the fits super tight through the stud hole and bolt that long idler in. Use some sort of locking bolt and an thick hardened washer to cover the taper hole and support the end bearing shaft. Don't tighten to too tight though. It will bind the bearing inside the idler. Keep tightening and moving the idler and you will feel it get harder to turn.
For some reason there was a 67 idler stud type Kmember in my 68 Barracuda. I ran the through hole 68 idler for about 4 years.
Re: Steering Center Link Binds on Oil Pan [Re: autoxcuda] #374560
07/17/09 11:13 AM
07/17/09 11:13 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Can the 67 and back K frame idler arm mount be altered by welding on a lower bracket so that it supports the 68 style idler correctly, with a hole in the new lower bracket for the bolt to pass thru?
Re: Steering Center Link Binds on Oil Pan [Re: autoxcuda] #374561
07/17/09 11:39 AM
07/17/09 11:39 AM
Virginia
Virginia
Thanks Autox. Thats what I was thinking about doing. Was your stud tapered? Mine is. Do you think that will be an issue? If you ran it like that for 4 years and never had a problem its safe to say your good. I might have to drill it out though. The through bolt is 9/16" and the stud uses a 1/2" nut.
Re: Steering Center Link Binds on Oil Pan [Re: Sixpak] #374562
07/17/09 11:43 AM
07/17/09 11:43 AM
Virginia
Virginia
There is room to do it but the k-member has to come out. And you'd have to weld the bracket on top. If you mounted the idler arm on bottom the center link would be crooked left to right and you'd have ground clerance issues.
