Re: metering rods how do they work ??
[Re: mjk5thave]
#371795
07/10/09 10:15 PM
07/10/09 10:15 PM
Posts: 1,443 Maryland
Dads426
Maryland
The fatest part of the rod drops down in the jet at idle; the thinnest at wide-open throttle. Vacuum pulls the rod(s) down against a spring at idle and at wide open throttle vacuum drops to near zero and the spring pushes the rod up out of the jet.
Look for any wear marks on the rod holder to determine where the rod was inserted.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: mjk5thave]
#371796
07/10/09 10:36 PM
07/10/09 10:36 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
What year BBD? If there is a "tin top?" They adjustable. Got to www.slantsix.org there is a sticky in the engine section. Click on that and there is a video on how to adjust them! Way cool! If you need the stuff from the carb repair kit I can either type it out or scan and email it.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: mjk5thave]
#371799
07/11/09 10:51 AM
07/11/09 10:51 AM
Rug_Trucker
No adjustment on the rods on that carb. Make sure you have the spring under the step up piston.
