Re: New Paint job on a budget thread.
[Re: Roadster_wa]
#37114
07/17/07 08:40 AM
07/17/07 08:40 AM
Thank you lads, didn’t mean to post just to Marq, I’d been reading his website looking for quantities as I believe Marq found the Brightside alternative to Rustoleum. I also meant to say 70% of my car will be in original black paint, the rest will be in primer, I am hoping to paint the whole car. Brightside is my last chance to find a paint here in Poland to do this job, if the Polish agent can supply, which I am still waiting to find out? If I draw a blank with the Brightside then I’ll have to bite the bullet and use the local paint shop
[Re: Marq]
#37116
07/17/07 12:40 PM
07/17/07 12:40 PM
Thanks Marq. I have found a guy who's located in Gdansk, he's a stockist of "some" Interlux paints but isn't sure he's got any stock of the Brightside in Gloss Black. He's on holiday just now, hence his inability to give me an answer. Sounds like a one man band operation, so I'll have to wait till he's back off holiday to find an answer. I'll buy 4 litres so if he doesn't stock maybe he'll get some, my problem is I leave here beginning of September, so the clock is ticking. Let me ask whilst I'm writing, do I need any of the #333 thinners for anything whatsoever, if I do I'll get some, I don't want to get stuck for lack of something simple? By the way, very helpful forum and it's been a pleasure reading all this regardless of how my project turns out. I really have learned a great deal about the "mysteries" of painting a car.
#37117
07/17/07 04:17 PM
07/17/07 04:17 PM
Posts: 575 Canada
Marq
mopar addict
mopar addict
Canada
Given the difficulties you are encountering... I would say that you can substitute safely the pure mineral spirits instead of the 333 thinner. The pure mineral spirit is probably more commonly available over there and probably quite a bit cheaper then the small tin of 333 thinner. I used both on my car and there wasn't much of a difference in drying time etc.
One nice thing... is that if you are lucky and can do your car with 2 cans of Brightside... you will have enough paint left to go and buy another disposable car and give it a matching paint job ( or better yet charge for your paint and services to do some other chaps car and recover your investment ).
I am curious about the availability of the 4 inch high density foam rollers over there in Poland.
[Re: Marq]
#37118
07/17/07 07:11 PM
07/17/07 07:11 PM
Ok,I hit the car with some 400 (only stuff I had that could be used with water) and it came out really smooth. There are some imperfections but Ill let the picture do the talking. I rubbed it down with spirits and Im about to go mix up some more paint and do a second coat. http://s14.photobucket.com/albums/a325/Ghia109/?action=view¤t=P1040726.jpg
[Re: Marq]
#37119
07/17/07 07:39 PM
07/17/07 07:39 PM
Thanks Marq mineral spirits here are quite easily available so I'll stick with them if I get the Brightside. Seeing as I've never painted before I might need the extra paint for practice and any misfortunes, now or later. I did manage to find some 4" rollers with squared off ends, the only other type with a rounded end I have seen are 6". I can't say I've really looked too far for foam rollers so there may be others available I've not spotted yet. Now here is a question that's had me thinking. It seems to me that when I roller a thicker layer of paint I'm going to get an orange peel effect. I am wondering what percentage of a coat of paint comprises this orange peel paint. I'm simple thinking that if a thick coat is applied and say 30% is removed then it might be better than removing 30% of a thinner coat. I know some guys don't get much of this orange peel, but being a rookie I'm just not sure I'll achieve such skill. If I've a decent thickness left I've the patience to polish and have a Porter-Cable and Farecla polishes. I think the rollering of paint is going to be my weak point, so I'm thinking how to achieve a decent job if I don't get the rollering quite right. Hope I've explained myself correctly here?
#37122
07/17/07 10:08 PM
07/17/07 10:08 PM
Posts: 575 Canada
Marq
mopar addict
mopar addict
Canada
It would be better to lay multiple thin coats... then attempt to rush the job by laying on thick coats.
A thin coat dries more thoroughly and completely then a thick coat.
Orange peel 'usually' occurs when you rush your next coat of paint on to the previous layer of paint.
What happens with a thick layer is that the outer skin hardens first and traps the wetter layer between the body and the outerskin of the paint. So when you add the next coat of paint too early it tends to soften up the previous outer layer. It them moves around on the previous uncured middle layer creating the wrinkle or orange peel type effect.
If you put on a thin layer... it takes less time for that middle wet layer to evaporate and harden. So when you add the next coat of paint things don't come alive underneath the latest coat of paint.
I really think the key to orange peel avoidance it to provide adequate time for each layer of paint to evaporate and cure ( or harden ).
The problem with going with thicker layers, expecting peeling and then planning to sand back the wrinkles is that you don't get a uniform outer layer of paint. Instead the outer layer is composed of the last coat of paint plus peaks from various wrinkle layers below. Also... you are doing more agressive and lower grit size to cut back the peeling.
BUT IF you go with the thinner coats... and can do so with minimal peeling... in the end you will probably find yourself just doing some light 800, 1000 or 1500 grit wet sanding to do the final sanding. That to me is less work then trying to knock back orange peel and then having to wetsand the knocked back surface up to a level where it can take an acceptable polishing and waxing.
[Re: Marq]
#37123
07/17/07 10:41 PM
07/17/07 10:41 PM
7D9LRE that trailer certainly looks nice now, thanks for sharing that information, give me more hope. Thanks Marq I do see the logic in what you are saying and will follow it when I paint. I would probably be more settled if I was practicing with the correct pain instead of some Polish product which is quite different to anything suggested on this thread. Maybe I'll try ordering a very small can of Brightside from the UK as postage might not be so savage and it'll give me a chance to get a "feel" for the real paint. Thanks again for your help.
[Re: Roadster_wa]
#37126
07/18/07 10:46 AM
07/18/07 10:46 AM
I'd go with a red/yellow mix, and try a few ratios until you got what you wanted. If you used a white with a tint, I think you'd end up with a pastel peach color!
[Re: Roadster_wa]
#37127
07/18/07 12:00 PM
07/18/07 12:00 PM
Ok, because the orange in Rustoleum is limited to the Safety Orange, (So far and not sure about that color) I'm pretty much leaning to trying to mix the yellow and red to get the "Harley" orange. Not being much of a paint guy, I'm guessing that a 50 / 50 mix of red and yellow will get me the basic orange. Needing a red orange, maybe the 45 /55 red mix will get me close. Any paint gurus out there have an opinion of what rustoleum red I should use and maybe a starting point of the mix if I'm going in the wrong direction?
Option #2 would be to buy a Gloss white and try to get Home Depot to tint it based on the color card that matches the paint. Would the Tint mix in with the white like a base?
Yet another concept picture:
You might also look into Van Sickle tractor paint (another alkyd enamel like Rustoleum) ...they carry "AC Orange" as a stock color:
Don't trust that card though...on this monitor the colors are way off from what I've seen in person. The colors are actually a lot brighter. They also list a bunch of "custom colors" here:
http://www.vansicklepaint.com/mntcstmclrs.htm
They list Kubota Orange, which might be closer to what you're looking for...they also have about 15 other oranges.
[Re: Marq]
#37128
07/18/07 12:26 PM
07/18/07 12:26 PM
Roadster, I would also recommend www.topsecretcoatings.com. It seems to be a very good paint too, and if you send them a color swatch, they will color match for you.
#37129
07/18/07 02:02 PM
07/18/07 02:02 PM
Yeah as I mentioned earlier the ac orange is much more reddish than safety orange, and I think is a close match for the Harley color.
#37130
07/18/07 07:02 PM
07/18/07 07:02 PM
Looks like you'll have a much better restart. From the picture you seem to have a good base. Do invest in finer grit for the remainder of your progress.
I'll start rolling over the weekend. I'll post some pics as I go. Hope it will come out as nice as Roadster's Vette.
[Re: Roadster_wa]
#37131
07/18/07 08:00 PM
07/18/07 08:00 PM
Here's the safety green, I didn't spend too much time on prep though since this was my test panal. Looks more like Grabber green. Ace rust stop safety green, they stock the same safety colors and popular colors as rustoleum. Also can mix about any color you would want. This really picked up the shine with the maguires carnuba wax.
#37132
07/18/07 10:02 PM
07/18/07 10:02 PM
