Distributor wires-pos/neg UPDATED #370897
07/09/09 11:18 AM
07/09/09 11:18 AM
Marysville, O-H-I-O
70Cuda383 Offline OP
Marysville, O-H-I-O
I'm finally getting around to wiring up the MSD ignition to my big block. I have a mopar electronic ignition distributor with a grey and black wire and the rubber 2 pin connector.
my 1970 Cuda wire diagrams are all for points ignitions
the aftermarket chrysler electronic ignition diagram just says "to distributor plug" and doesn't say which color wire is positive or negative
MSD website says the distributor wires are orange and black...mine are black and grey.
the plug from the electronic ignion box has a grey wire with black tracer also marked "fusible link" and a brown wire with white tracer.
here's how the wires from distributor plug match up to the plug from the stock electronic ignition box:
Orange box side / Distributor side
Grey w/Black tracer -- Black
Brown w/ white tracer -- Grey
Thanks for making it confusing! (distributor and orange box all came from the same source)
I'm assuming that the Black wire out of the distributor is ground, and the grey wire out of the distributor is positive?
more importantly, being a magnetic pick up that is either "open" or "closed"...does it even matter?
**Photobucket sucks**
Re: Distributor wires-pos/neg [Re: 70Cuda383] #370898
07/09/09 12:38 PM
07/09/09 12:38 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Yeah, you would think after all these years they would show some more of the possible wiring combinations out there.
I guess they seem to assume you can figure it out.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Distributor wires-pos/neg [Re: 70Cuda383] #370899
07/09/09 12:48 PM
07/09/09 12:48 PM
Maybe you can tell from the original plug? I believe the white/ red units, the white connects to the distributor male prong on the original plug.
Neither of the two wires is ground. The output of the dist. is an AC pulse. Because it goes both positive and negative, the polarity will affect timing (phasing) at the dist, so I'd assume that polarity is important.
Even though you probably know the phasing discussion turned into a huge fiasco, I'd bet that changing the polarity of those wires WILL change dist. phase by a large amount.
I would not cut off the original plug. those two prong plugs should be available easily at most any NAPA or other parts store, probably sold in pairs.
Re: Distributor wires-pos/neg #370900
07/09/09 02:54 PM
07/09/09 02:54 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
I don't WANT to cut off the plug! I am leaving the plug on the distributor, and I have the opposite plug that I removed from the wire harness that used to be on the Cuda, and I want to solder THAT plug and wires onto the MSD box, so that I can plug it straight into the stock distributor...but I cannot do that unless I know which wire is positive, and which wire is negative. the MSD shows green as the distributor negative, and purple as the distributor positive.
the spare plug I have has the brown/white and grey/black wires, exactly like the orange box ignition. the problem with that, is my wire diagram that came with the orange box simply shows "To distributor" and doesn't call out positive or negative...due to the design of the plug, it's impossible to screw that up, so they must have figured you didn't need to know which one was which.
that's all fine and dandy when you're plugging the orange box into the stock distributor because it's a simple "plug and play" but now that I want to put that style plug on the MSD box, I need to know which wire to connect to the green one from the MSD, and which wire to connect to the purple MSD...and the fact that they changed the color of the wires at the distributor plug further complicates things!
Re: Distributor wires-pos/neg [Re: 70Cuda383] #370901
07/09/09 02:58 PM
07/09/09 02:58 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
So, here are my options!
MSD wires soldered to plug from orange box plugged into stock distributor
Green soldered to Grey w/Black tracer plugs into Black
Purple soldered to Brown w/ white tracer plugs into Grey
OR
Purple soldered to Grey w/Black tracer plugs into Black
Green solderd to Brown w/ white tracer plugs into Grey
Re: Distributor wires-pos/neg [Re: 70Cuda383] #370902
07/09/09 03:10 PM
07/09/09 03:10 PM
So Cal
So Cal
hard to tell but I think from this picture the female end of the distributor’s end of plug is the neg.
Another pict from bouchillon performance
Re: Distributor wires-pos/neg [Re: HealthServices] #370903
07/09/09 03:21 PM
07/09/09 03:21 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
No experience in this particular situation, but on the OE set-up, you can do a scratch test with the harness (the male prong of the 2 pin connector).
Usually, the female connector on a wiring harness supplies power. This is so it won't short out when disconnected. AC is a whole different situation, though.
Re: Distributor wires-pos/neg [Re: RodStRace] #370904
07/09/09 03:42 PM
07/09/09 03:42 PM
So Cal
So Cal
or you could always go here.
http://www.msdignition.com/forum/index.php
Re: Distributor wires-pos/neg [Re: HealthServices] #370905
07/09/09 04:19 PM
07/09/09 04:19 PM
Medford OR
FrankenScamp Offline
Medford OR
call 'em...they've helped me. good luck!
Re: Distributor wires-pos/neg [Re: FrankenScamp] #370906
07/09/09 04:24 PM
07/09/09 04:24 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
I think that's what I'm gonna have to do. the problem I'm running into is the wire diagram that MSD provides, shows a black and orange wire from the factory distributor. the buchillion pictured above shows black and red. the distributor that I have is black and grey. it's probably a safe bet that in this case, black = black, and orange/red = grey...but then again...
another similar question, since I'm new to MSD ignitions...where do I put the magical "rev limiter chip"? I don't see anywhere to plug one in, and no where in the diagrams or literature does it say how or where to install the rev limiter chip.
not that I absolutely need one, but might as well put one in for insurance. my dyno graph shows that I have no reason to spin this motor faster than 6200 rpm so I might as well toss in a 6200 chip incase I miss a shift or get stupid with it.
Re: Distributor wires-pos/neg [Re: 70Cuda383] #370907
07/09/09 04:46 PM
07/09/09 04:46 PM
So Cal
So Cal
6A no rev control
6AL has the spot for rev chip
http://www.msdignition.com/info.aspx?taxid=4&taxid2=94
Re: Distributor wires-pos/neg [Re: HealthServices] #370908
07/09/09 04:54 PM
07/09/09 04:54 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
6A no rev control
hmmm...I'll have to look at it again when I get home, I'm almost positive the top of the box says "MSD 6AL" but Idon't remember a spot on the side for a chip, all I can remember is a port for the tach to plug into...I think.
Re: Distributor wires-pos/neg [Re: 70Cuda383] #370909
07/09/09 05:03 PM
07/09/09 05:03 PM
So Cal
So Cal
On this 6AL the white plug in is the chip
6AL without the spot on the bottom
Re: Distributor wires-pos/neg [Re: 70Cuda383] #370910
07/09/09 05:13 PM
07/09/09 05:13 PM
OR
Like I said, it probably will trigger either way, but will probably affect rotor phasing. All I know to suggest is try it and check it, or call MSD You'd think for the money they charge, they'd specify which.
Re: Distributor wires-pos/neg #370911
07/09/09 05:23 PM
07/09/09 05:23 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
OR
I plan on it when I have the opportunity during business hours, and I can look at some things again...looking at a diagram online, it looks like the female side of the plug on the distributor is the negative...the MSD diagram is actually quite helpful, except my distributor wires are black and grey, not black and orange like MSD shows. I assumed the black on my distributor is still the negative and I have a grey for positive instead of red...I just wanted to verify first from someone who might have "been there, done that"
then the comment about the female/male side of the plugs triggered the idea to look at the diagram again, looks as if the female plug on the distributor IS the negative, as this diagram indicates...but, I don't have my distributor infront of me to verify that MY black wire also goes to the female side of the distributor plug.
once I look at it all again and verify a few things, I'll give MSD a call.
Re: Distributor wires-pos/neg [Re: 70Cuda383] #370912
07/09/09 08:24 PM
07/09/09 08:24 PM
I went to their site but was unsure of what diagram to follow. For the moment, I"d assume that drawing to be your answer.
As I said earlier, though, you did not need to cut the connector off your old system--you can buy those cheap (they are in the same series as the inexpensive 4 wire trailer connectors)
Re: Distributor wires-pos/neg #370913
07/09/09 08:48 PM
07/09/09 08:48 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
yes I know it's a common plug, but this was an extra system, and it was free
this is all on the Dakota, the harnesses that were on the Cuda are nothing more than parts donors now, becuase of how old and butchered it was. when it's ready, it'll get all new wires
Re: Distributor wires-pos/neg [Re: 70Cuda383] #370914
07/09/09 09:03 PM
07/09/09 09:03 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I would hook up black to black and assume grey is comparable to orange/red/whatever is not black. The only think that will happen if they are mixed up is the truck running rough (ie dist. out of phase) or not wanting to start at all.
I'm away from home but can check it out when I get back from work on Friday. One of my trucks has an MSD with a black/grey harness coming from the dist.
Re: Distributor wires-pos/neg [Re: Jeremiah] #370915
07/13/09 12:36 PM
07/13/09 12:36 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
the black wire from the distributor with the female side of the plug is the negative! I hooked it up, started the engine, and it fired right up.
I was pleasantly surprised, because I don't have an RPM chip in the MSD6AL and didn't know if it needed one just to run, and I wasn't positive that I had the distributor wires hooked up correctly.
so, either the black wire IS the negative, or, it doesn't matter how it's wired up, because it's running fine as-is.
Re: Distributor wires-pos/neg [Re: 70Cuda383] #370916
07/13/09 12:42 PM
07/13/09 12:42 PM
So Cal
So Cal
Maybe we should have this updated somewhere, so if people wonder...
