Best sb intake for turbo application?
#369552
07/07/09 09:05 PM
07/07/09 09:05 PM
Posts: 408 Tampa, Fl
valiantboy
super gas
super gas
Tampa, Fl
building a turbo 318. nothing fancy, just a street driver. will a single plane work better than a dual plane? im thinking of somthing in the "mid-height" intake, maybe a torquer 2, weiand xcellerator.. somthing with smaller ports to help keep velocity up. am i thinking right?
I'm WAY too baked to drive to the devil's house.
Re: Best sb intake for turbo application?
[Re: 9 Sec Phill]
#369554
07/07/09 09:18 PM
07/07/09 09:18 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I think a single plane is ideal but in the end its not super important I don't think. A friend of mine is just getting the bugs worked out of his home built 85 mustang with a HX40 turbo. Its a stock 92 302(freshened) with a small cam, a dual plane intake, holley carb, and HX40 turbo running 6psi. The dual plane doesn't seem to be holding it back any as its making some steam.
68 Barracuda Formula S 340
[Re: Bad340fish]
#369555
07/07/09 09:41 PM
07/07/09 09:41 PM
Posts: 1,090 north cakalaky
instigator
north cakalaky
Carbed or fuel injection...to me this is the biggest question....carbed means the extra fuel has to also travel into the ports with the same velocity..fuel injection, doesn't matter a whole lot, the fuel is not introduced till it is almost in the cylinder head.
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
Post deleted by Defbob
[Re: instigator]
#369556
07/07/09 10:16 PM
07/07/09 10:16 PM
