1/8th mile conversion
#368776
07/07/09 12:25 AM
07/07/09 12:25 AM
Posts: 501 Port Mcneill,B.C.Canada
Islandcuda
Hi all, we just had a test and tune session at our local airport for 1/8 mile, we had cement burnout boxes vht and lights for single runs. I ran a 6.48 in the 1/8th, can anyone tell me what that converts to in 1/4 mile. I can,t find last years time slips, thanks Tim
67 cuda new best 1.395 60 10.240 at 128.58mph
Re: 1/8th mile conversion
[Re: Islandcuda]
#368778
07/07/09 12:34 AM
07/07/09 12:34 AM
Posts: 549 Bristol, Va
fasteddie
Bristol, Va
Multiply by 1.58 should be pretty close.
6.48 X 1.58 = 10.24
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
[Re: fasteddie]
#368779
07/07/09 12:40 AM
07/07/09 12:40 AM
Islandcuda
Thanks guys, there were traction issues, I,m just hoping I,m not in the 9,s at real strip as I just don,t want to go there yet, tim
[Re: Islandcuda]
#368781
07/07/09 03:35 AM
07/07/09 03:35 AM
Posts: 8,858 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
1.59 was the formula i was told to use
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: CokeBottleKid]
#368783
07/07/09 08:14 AM
07/07/09 08:14 AM
Islandcuda
We had no mph, this only did times and you had to reset after every run, but we did discover that in the future our local airport will work.
[Re: Dodgem]
#368786
07/07/09 11:02 PM
07/07/09 11:02 PM
Posts: 315 Russiaville, IN
mopar376d
Russiaville, IN
I just ran 10.59 (1/4) & 6.70 (1/8th)
6.70 * 1.58 = 10.586
Why does divorce cost so much?
Because it is worth it!!!!!
[Re: 440Jim]
#368791
07/08/09 11:14 AM
07/08/09 11:14 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Different cars will have different 1/8 to 1/4 ratios. But 1.57-1.59 should cover it, if the car was working properly.
wouldn't it also depend on gearing??? or is that strictly set up for 1/4 mile cars that run 1/8's Some of those 1/8 mile cars have such high gears I doubt they'd calculate out w/ that.
[Re: Mr.Yuck]
#368792
07/08/09 11:53 AM
07/08/09 11:53 AM
Posts: 130 Loudonville, Ohio
nitrojoe
Loudonville, Ohio
swingin is right its all about they way you have your car set up. If you have it geared where its making power on the top end your going to be on the slow side 1/8th mile wise, if you have the valves set for low end power, well your going to be fast on 1/8th mile, gearing, valve setting and others will play a big roll on how fast you can go in 1/8th mile. My roadster went 9.20's all the time on quarter mile, but when i went to Pacemakers i was running 5.80's and 5.90's which is in the 8's so........
Just my 2 cents
Nitro Joe Jackson
[Re: toddd]
#368794
07/08/09 08:25 PM
07/08/09 08:25 PM
Posts: 2,864 IN
Irun5snd8th
IN
According to the 1.58 theory a 6.19 shows 9.78 and I ran 9.85 so its not too far off.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
