360 supercharged camshaft help
#367138
07/05/09 12:27 PM
07/05/09 12:27 PM
Posts: 1,445 Sterling Heights, Michigan 483...
daniel_depetro
Quick background: My dad wants to order a camshaft for his 1972 Dart. It has a noe stock 360 that we pulled out of a 1974 (I think it was) low mileage (~43,XXX) Dodge Truck and it runs great. He has his small B&M 177(?)supercharger on it but wants to add a bit more camshaft. When we swap the camshaft we will get the correct valve springs and add a double row true roller timing chain. My Question:What is the "largest" camshaft we could put in there and have it still use the stock torque converter? Useless babble:I was kind of hoping to use a fast rate ~.485"(I)/495"(E) lift camshaft with 112/114 lobe seperation. We've used this cam in a couple other supercharged 360s and had good luck with them, but this is our first automatic transmission vehicle and I don't know if that cam will like the factory converter.
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
Re: 360 supercharged camshaft help
[Re: daniel_depetro]
#367139
07/05/09 04:12 PM
07/05/09 04:12 PM
RapidRobert
I want one of them . What rpm did that cam idle at in the other motor?
[Re: Rug_Trucker]
#367141
07/05/09 04:50 PM
07/05/09 04:50 PM
daniel_depetro
The .484" lift came?
There is some elcheapo 2200 stall units available. No special name on them.
I don't know if I'd trust a cheap converter. I've heard so many bad stories about them. Besides he isn't going to spend money on one anyways. You don't understand how cheap he is. $250.00 is a lot of money to him.
#367142
07/05/09 04:55 PM
07/05/09 04:55 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Been running a Daaco or something like that for 7 years in my 6000lb van. Helps motivate that tank.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: RapidRobert]
#367145
07/05/09 06:20 PM
07/05/09 06:20 PM
daniel_depetro
I have no idea at what RPMs the idle is set at. The current car we have the other supercharged 360 in is a 1941 Dodge sedan (2-door). It is a shell of a car with no interior and open exhaust. There is no tach in the car. It seems pretty mild actually, at least to me.
I'll check out those generic converters a little more, however all of our cars have A-883 4-speeds in them.
[Re: racincuda]
#367147
07/05/09 09:35 PM
07/05/09 09:35 PM
daniel_depetro
The '41 Dodge was put together for having fun in the parking lot and at the strip now and then. Unfortunately our building burnt down so we lost our 330-foot lanch pad (with a nice shut down area)
[Re: DaytonaTurbo]
#367149
07/05/09 09:42 PM
07/05/09 09:42 PM
daniel_depetro
What cam is in there now?
I have no idea, the engine is bone stock right now (with the exception of the supercharger intake manifold, supercharger, and Holley 4-bbl. carburetor). The engine was originally a 2-bbl. I believe, which is weird on a truck, isn't it?
