440 main bearings with O/S thrust surfaces?? #367064
07/05/09 06:24 AM
07/05/09 06:24 AM
Adelaide, SOUTH Australia
REDNICK Offline OP
REDNICK  Offline OP
Hi,
Can anyone tell me which brand name bearing manufacturer makes the #3 bearing with an oversize thrust "lip" to take up the thrust surface wear which is quite often evident in RB cranks ?
The rest of the crank is std/std and in great condition. It will now be used in a 4 speed car, so the thrust issue needs to be sorted correctly.
Probably would have let it go if it was going back to an auto trans...
Nick
Re: 440 main bearings with O/S thrust surfaces?? [Re: REDNICK] #367065
07/05/09 09:58 AM
07/05/09 09:58 AM
South Jersey
JerseyJoe Offline
JerseyJoe  Offline
South Jersey
I believe the '74 and later #3 bearing has a larger flange but it needs to be in a '74 or later cap because the cap will have a larger machined recess to accomodate the larger bearing.
Re: 440 main bearings with O/S thrust surfaces?? [Re: JerseyJoe] #367066
07/05/09 10:29 AM
07/05/09 10:29 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
The older pre about 74 mains had the narrow thrust flange and the later the wide thruust flange. You can use the older narrow thrust bearing in the newer block but you can't use the newer wide thrust bearings in the older blocks.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
