Hi,
Can anyone tell me which brand name bearing manufacturer makes the #3 bearing with an oversize thrust "lip" to take up the thrust surface wear which is quite often evident in RB cranks ?
The rest of the crank is std/std and in great condition. It will now be used in a 4 speed car, so the thrust issue needs to be sorted correctly.
Probably would have let it go if it was going back to an auto trans...
Nick
