Re: R5P7 DART TO TEST FRIDAY
[Re: Pat7272]
#364214
07/02/09 09:40 AM
07/02/09 09:40 AM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Sounds fun! What does the car weigh, and does it still have the NASCAR spec cam in it?
Yes, still has small 248/258 cam in it..
should weigh somewhere around 3150 ish or so with him in it, maybe 3200 at most.
[Re: 408strokerdart]
#364216
07/02/09 09:43 AM
07/02/09 09:43 AM
B3422W5
Portage,michigan
This is a picture before he got it done, doesnt do the car justice at all
[Re: SB449VALIANT]
#364224
07/02/09 11:12 AM
07/02/09 11:12 AM
B3422W5
Portage,michigan
Scot doesnt get on here much, but the car by our estimates is liable to turn anywhere in a wide ET area. We arent real sure how far the 8 inch convertor that was behind an old motor of his will flash behnd this motor(but suspect it might be light convertor wise)wont know until he tests it. If the stars were aligned, the car could run mid 9's, if its way off it could go 10.30-10.40. My personal guess is it will run 9.70-9.90 like it sits before he starts dialing in the combo. He will have to dial in the suspension/shock, etc, play with launch rpms and see where the motor likes being shifted at, a whole lot of variables Nobody has yet to do this, so who knows, but i cant wait to hear that thing in the water box
[Re: B3422W5]
#364225
07/02/09 01:55 PM
07/02/09 01:55 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
at what rpm did it make 735hp??
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: ProSport]
#364227
07/02/09 04:26 PM
07/02/09 04:26 PM
B3422W5
Portage,michigan
Nice car Scott! Please post your results!
No more smoking for Don! He's gonna need a big block when he starts eating instead of smoking.
Remind me to kill you later, Bob...i weigh 280 currently, i wouldnt get in the 12's at that weight with most big blocks
[Re: Irun5snd8th]
#364229
07/02/09 05:35 PM
07/02/09 05:35 PM
B3422W5
Portage,michigan
He is figuring to zing it 8500-8800 or so, he is hoping it has ENOUGH gear BTW that 735 ponies was with a 390 carb on it ..it has a carb shop 950 on it now that dyno was done at Arringtons shop.... Scott took one of the heads off and had a guy pretty famous around these parts(Jerry Arnold)flow it, and it stopped just a smidgen short of 400cfm
