Page 1 of 4 1 2 3 4
R5P7 DART TO TEST FRIDAY #364210
07/02/09 08:49 AM
07/02/09 08:49 AM
New Smyrna Beach FL
scottb Offline OP
scottb  Offline OP
New Smyrna Beach FL
Im going to test friday night with the new motor comb. This will be the frist time out with the car its a brand new car .Here is a run down of the car and motor 68 dart ladder bar 10.5 tire car tubalar front end 904 trans A&A brake 9 inch ford 513 gear motor r5p7 motor the motor dyno at 735hp with a 390 carb I will be running a 950 from the carb shop .Feels mighty impressive cannot wait to see it go .PS on a side note B3 Don has to stop smoking once the car goes down the track a little bet him and I had I would also like to thank Bondobob for his help getting this car running and my wife the most for letting me put this car together the last 8 wks
Re: R5P7 DART TO TEST FRIDAY [Re: scottb] #364211
07/02/09 08:56 AM
07/02/09 08:56 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Good luck with it Scott!
Re: R5P7 DART TO TEST FRIDAY [Re: Bigcube] #364212
07/02/09 09:11 AM
07/02/09 09:11 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
Good luck with it,so how about a pic of the car.
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: R5P7 DART TO TEST FRIDAY [Re: moparmxz] #364213
07/02/09 09:21 AM
07/02/09 09:21 AM
La Vernia, Texas
Pat7272 Offline
Pat7272  Offline
La Vernia, Texas
Sounds fun! What does the car weigh, and does it still have the NASCAR spec cam in it?
Re: R5P7 DART TO TEST FRIDAY [Re: Pat7272] #364214
07/02/09 09:40 AM
07/02/09 09:40 AM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Yes, still has small 248/258 cam in it..
should weigh somewhere around 3150 ish or so with him in it, maybe 3200 at most.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: R5P7 DART TO TEST FRIDAY [Re: Pat7272] #364215
07/02/09 09:40 AM
07/02/09 09:40 AM
Out West
408strokerdart Offline
Out West
Good luck with it, sounds like fun. Can't wait to hear results.
Re: R5P7 DART TO TEST FRIDAY [Re: 408strokerdart] #364216
07/02/09 09:43 AM
07/02/09 09:43 AM
Portage,michigan
Portage,michigan
This is a picture before he got it done, doesnt do the car justice at all
1.41 best 60 foot
6.56 at 104.17
Re: R5P7 DART TO TEST FRIDAY [Re: B3422W5] #364217
07/02/09 09:47 AM
07/02/09 09:47 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I hope youys are testing at Martin on Friday,not Osceola.Traction has been an issue lately at Osceola,even for guys that don't usually have problems hooking.
Re: R5P7 DART TO TEST FRIDAY [Re: Dunnuck Racing] #364218
07/02/09 09:53 AM
07/02/09 09:53 AM
Portage,michigan
Portage,michigan
Yep...131 tomorrow night
1.41 best 60 foot
6.56 at 104.17
Re: R5P7 DART TO TEST FRIDAY [Re: B3422W5] #364219
07/02/09 09:56 AM
07/02/09 09:56 AM
Northern Indiana
Northern Indiana
Glad to hear it is together,hope everything goes well!
Re: R5P7 DART TO TEST FRIDAY [Re: Dunnuck Racing] #364220
07/02/09 10:51 AM
07/02/09 10:51 AM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
cant wait to hear the results
good luck Scott
Re: R5P7 DART TO TEST FRIDAY [Re: Dunnuck Racing] #364221
07/02/09 10:52 AM
07/02/09 10:52 AM
east coast
Otherlane Offline
Otherlane  Offline
east coast
What E.T are you hoping to get?
Re: R5P7 DART TO TEST FRIDAY [Re: Otherlane] #364222
07/02/09 10:59 AM
07/02/09 10:59 AM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
that sounds sweet!!!
go get it!!
Re: R5P7 DART TO TEST FRIDAY [Re: Otherlane] #364223
07/02/09 11:01 AM
07/02/09 11:01 AM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
Re: R5P7 DART TO TEST FRIDAY [Re: SB449VALIANT] #364224
07/02/09 11:12 AM
07/02/09 11:12 AM
Portage,michigan
Portage,michigan
Scot doesnt get on here much, but the car by our estimates is liable to turn anywhere in a wide ET area.
We arent real sure how far the 8 inch convertor that was behind an old motor of his will flash behnd this motor(but suspect it might be light convertor wise)wont know until he tests it.
If the stars were aligned, the car could run mid 9's, if its way off it could go 10.30-10.40. My personal guess is it will run 9.70-9.90 like it sits before he starts dialing in the combo.
He will have to dial in the suspension/shock, etc, play with launch rpms and see where the motor likes being shifted at, a whole lot of variables
Nobody has yet to do this, so who knows, but i cant wait to hear that thing in the water box
1.41 best 60 foot
6.56 at 104.17
Re: R5P7 DART TO TEST FRIDAY [Re: B3422W5] #364225
07/02/09 01:55 PM
07/02/09 01:55 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
at what rpm did it make 735hp??
Re: R5P7 DART TO TEST FRIDAY [Re: sixpackgut] #364226
07/02/09 04:21 PM
07/02/09 04:21 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Nice car Scott! Please post your results!
No more smoking for Don! He's gonna need a big block when he starts eating instead of smoking.
Re: R5P7 DART TO TEST FRIDAY [Re: ProSport] #364227
07/02/09 04:26 PM
07/02/09 04:26 PM
Portage,michigan
Portage,michigan
Remind me to kill you later, Bob...i weigh 280 currently, i wouldnt get in the 12's at that weight with most big blocks
1.41 best 60 foot
6.56 at 104.17
Re: R5P7 DART TO TEST FRIDAY [Re: B3422W5] #364228
07/02/09 05:14 PM
07/02/09 05:14 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Me thinks 9.50's should be easily accomplished if the dyno was true. I hope you like RPM's cause with a 5.13 gear you are gonna see a bunch with that tire combo on there. I would like to be at the stripe when that thing sings past
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: R5P7 DART TO TEST FRIDAY [Re: Irun5snd8th] #364229
07/02/09 05:35 PM
07/02/09 05:35 PM
Portage,michigan
Portage,michigan
He is figuring to zing it 8500-8800 or so, he is hoping it has ENOUGH gear
BTW that 735 ponies was with a 390 carb on it ..it has a carb shop 950 on it now
that dyno was done at Arringtons shop....
Scott took one of the heads off and had a guy pretty famous around these parts(Jerry Arnold)flow it, and it stopped just a smidgen short of 400cfm
Page 1 of 4 1 2 3 4
