Where to buy left hand thread wheel studs #363426
07/01/09 10:25 AM
07/01/09 10:25 AM
Blanchard, OK
Real-Fury Offline OP
Blanchard, OK
I thought this would be simple but apparently the auto parts houses (O'Reilly, NAPA, Advanced) don't carry left hand threaded wheel studs in their inventory. Where can I pick some of these up? Apparently the nuts are readily available but not the studs.
Thanks.
Butch
Re: Where to buy left hand thread wheel studs *DELETED* [Re: Real-Fury] #363427
07/01/09 11:06 AM
07/01/09 11:06 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Post deleted by 11sec68barracuda
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Where to buy left hand thread wheel studs [Re: 69L78Nova] #363428
07/01/09 11:37 AM
07/01/09 11:37 AM
Blanchard, OK
Blanchard, OK
Just checked the Year One catalog online and they only carry the R/H thread studs for Mopar. They sell one that states "will work on the L/H side" (that would be interesting) but no L/H thread studs.
Butch
Re: Where to buy left hand thread wheel studs [Re: Real-Fury] #363429
07/01/09 11:57 AM
07/01/09 11:57 AM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Time to convert to RH all around.
Re: Where to buy left hand thread wheel studs [Re: Pntastar69] #363430
07/01/09 12:07 PM
07/01/09 12:07 PM
Blanchard, OK
Blanchard, OK
Well, I can't argue with your logic. The car is totally stock and I've tried to keep it that way. So, I'd rather replace one stud than convert all to R/H....if it's possible. Beginning to look a little tough.
Butch
Re: Where to buy left hand thread wheel studs [Re: Real-Fury] #363431
07/01/09 04:06 PM
07/01/09 04:06 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Check with Mike Ross (Hemicuda). He is making the Rallye lug nuts and was talking about making the studs.
Re: Where to buy left hand thread wheel studs [Re: Snoopy] #363432
07/01/09 04:15 PM
07/01/09 04:15 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
No Mike said in the begining he didn't want to make the studs, he said he would make a R/H threaded nut with the bump & stanp L into it... But everyone said we need L/H threaded nuts so Mike tooled up & ran them but said in the beginning studs weren't available & it was gonna be a problem.. I'm not saying he won't make them, but I am saying he didn't want to go there because there are to many variables.. Kelsey Hayes or Bendix.. Drum or Disc.. Rear axle 7.25 8.25 8.75 9.75...
Re: Where to buy left hand thread wheel studs [Re: Real-Fury] #363433
07/01/09 04:33 PM
07/01/09 04:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Butch
Left hand studs are going to be VERY hard to find , they stopped making them , if you get lucky you MIGHT find some at an OLD parts store , otherwise you are going to have to change them . I would not trust knocking them out of an axle or hub and trying to reuse them either .
Re: Where to buy left hand thread wheel studs [Re: Real-Fury] #363434
07/01/09 05:02 PM
07/01/09 05:02 PM
Bloomington, Illernoise
cptn60 Offline
cptn60  Offline
What is the exact application?
This space available for rent
Re: Where to buy left hand thread wheel studs [Re: cptn60] #363435
07/01/09 07:38 PM
07/01/09 07:38 PM
Blanchard, OK
Blanchard, OK
It's needed for a L/H front drum/hub on a stock 1964 Plymouth Fury with 383. It has 10" inside diameter drum and the car was built in St. Louis. I mention St. Louis because I learned today that the Detroit built cars supposedly use a different stud PN.
I found an online reference source that says it should be a 610-135 stud (not the Plymouth PN) and a 611-026 nut. I've been able to find the nuts but the stud has been tough to locate. I've found a source for a used stud but would prefer using new.
It's amazing the conflicting information I've found but if you sort through it you can find what you need. But, it's been a real education process. I've learned more about 1964 Plymouths since purchasing this car 3-4 months ago than I've known about any car I've ever owned. Seems to be a matter of survival; you either learn it or you don't fix it.
Thanks!
Butch
Re: Where to buy left hand thread wheel studs [Re: Real-Fury] #363436
07/01/09 07:54 PM
07/01/09 07:54 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Well I did get mine at NAPA,,,but then later changed over to all right hand,again from NAPA
Re: Where to buy left hand thread wheel studs [Re: Real-Fury] #363437
07/01/09 07:55 PM
07/01/09 07:55 PM
ar.
bobs69 Offline
bobs69  Offline
ar.
I think i have some studs and lug nuts if you want them!!
Re: Where to buy left hand thread wheel studs [Re: Real-Fury] #363438
07/01/09 08:10 PM
07/01/09 08:10 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
nuts themselves are not hard to come up with.
All left hand studs were dis-continued last year from the manufacturer.
shown is all I have avail for pt # 610-135
I got your email btw
Re: Where to buy left hand thread wheel studs [Re: gtx6970] #363439
07/01/09 08:30 PM
07/01/09 08:30 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
So what are all of the hardcore restoration guys supposed to do if nobody makes them anymore?
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: Where to buy left hand thread wheel studs [Re: 69L78Nova] #363440
07/01/09 09:08 PM
07/01/09 09:08 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
same as any other hard to find part, dig dig dig to find them or pony up to a hi profile vender or do without
ALL left hand studs are dis-continued regardless of application
Re: Where to buy left hand thread wheel studs [Re: gtx6970] #363441
07/01/09 09:12 PM
07/01/09 09:12 PM
Blanchard, OK
Blanchard, OK
Please put my name on a couple of them if you will. I can either email you again or call, just let me know what you prefer. I don't want to take your entire supply but I'd like to have at least one spare.
Thanks,
Butch
Re: Where to buy left hand thread wheel studs [Re: gtx6970] #363442
07/01/09 09:14 PM
07/01/09 09:14 PM
midwest
sg333e Offline
super street
sg333e  Offline
super street
midwest
Bill, you probably also got my voice mail on this yesterday...but to be clear I am not him:) give me a call when you get a chance.
Hobbies and associated message boards: 1970 Cuda 440+6 FE5 H6X9 4 SP> Moparts.com 1987 Grand National (422rwhp/566tq)> TurboBuick.com 2008 BMW 335 TT 6MT> E90Post.com 2008 Gary Fisher HiFi Plus 29er > MTBR.com 2008 German Shorthair Pointer > Shorthairs.net
Re: Where to buy left hand thread wheel studs [Re: sg333e] #363443
07/07/09 09:22 AM
07/07/09 09:22 AM
Nanuet, NY
johntpr Offline
johntpr  Offline
Nanuet, NY
Here is another possible source
http://www.apexautosports.com/store.html
69 Daytona 4 speed
