foam for lift -off fiberglass hood... #360561
06/28/09 02:57 PM
06/28/09 02:57 PM
Ohio
racerAL Offline OP
racerAL  Offline OP
Ohio
where do you find the foam cubes that i see racers putting on their lift-off hoods to protect the top of the car while the hood sits on it?...i've tried foam from a regular seat cushion but it's not dense (stiff) enough..the weight of the hood immediately smashes it almost flat...the cubes i've seen being used appear to be very stiff and hardly give at all once the hood is set on the top of the car..where do you find this foam??
-1967 Plymouth Satellite #3555
446 cid on E-85
best 1/4 et 10.577 @ 127.58
best 1/8 et 6.722 @ 100.68
best 60ft. 1.419
Re: foam for lift -off fiberglass hood... [Re: racerAL] #360562
06/28/09 03:05 PM
06/28/09 03:05 PM
long island NY
Ari440 Online content
Ari440  Online Content
long island NY
I got mine from radiaters boxes the foam supports the radiater in the box
1.39 9.85 - 137 mph
Post deleted by Defbob [Re: Ari440] #360563
06/28/09 03:14 PM
06/28/09 03:14 PM
Re: foam for lift -off fiberglass hood... #360564
06/28/09 03:28 PM
06/28/09 03:28 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
I would say any GOOD upholstery shop should have some good DENSE foam ....
When I did my shipping of parts ... I used the most dense foam I could find to put on the bottom of the box to protect the part.
Re: foam for lift -off fiberglass hood... #360565
06/28/09 03:49 PM
06/28/09 03:49 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
any upolstery shop.
Yep. Buddy of mine has a shop and gets all that kind of stuff.
Re: foam for lift -off fiberglass hood... [Re: racerAL] #360566
06/28/09 04:04 PM
06/28/09 04:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I used a couple of pieces of those foam pool snakes,
same thing I used for the cables on the trailer tail
gate... just used silicone to glue them on the hood
Re: foam for lift -off fiberglass hood... [Re: MR_P_BODY] #360567
06/28/09 05:06 PM
06/28/09 05:06 PM
Morrow, OH
markz528 Online content
markz528  Online Content
Morrow, OH
Joann's Fabrics
Re: foam for lift -off fiberglass hood... [Re: racerAL] #360568
06/28/09 05:30 PM
06/28/09 05:30 PM
Corvallis,OR
540CUDA Offline
super street
540CUDA  Offline
super street
Corvallis,OR
Rollbar padding from Jegs, cut to length and angle you need. Stuck on with 3M weatherstrip adhesive. Has worked for me for 10yrs plus still on firmly.
PRH 540,T-ram,-1's tagged and insured. 9.24et 146.13mph 1.30 60'3300#s
Re: foam for lift -off fiberglass hood... [Re: markz528] #360569
06/28/09 09:17 PM
06/28/09 09:17 PM
Ohio
racerAL Offline OP
racerAL  Offline OP
Ohio
Joann's Fabrics
...that was the place i originally tried but the teen-aged girl working had no comprehension of what i was asking for... ..neither did the other 3 teen-agers that was working with her that day....lol....maybe i'll try again tomorrow hopefully there are a few different people working..as far as using roll bar padding...i need these to be at least 3 to 4 inches tall(if not taller)..how would i make roll bar padding that thick... ...stack them with addhesive? whats the biggest cube i could make with the padding?...thanks for the input
446 cid on E-85
best 60ft. 1.419
Re: foam for lift -off fiberglass hood... [Re: racerAL] #360570
06/28/09 10:01 PM
06/28/09 10:01 PM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
i use 4 big washing spunges from wally world glued to the 4 corners of my hood
cheap and easy
Re: foam for lift -off fiberglass hood... [Re: BobsProFab] #360571
06/28/09 10:28 PM
06/28/09 10:28 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Same as Bondo Bob, spunges . to get four inches you'll need to stack two together .
Re: foam for lift -off fiberglass hood... [Re: BobsProFab] #360572
06/28/09 11:30 PM
06/28/09 11:30 PM
Roanoke Va
gearjammerdart Offline
Roanoke Va
cheap and easy
Bingo!!!
Donald
69 Dart swinger 417 W8 Liberty 5 speed
6.03 @114/9.49 @141 on motor 5.30 @131 on juice 1/8th mile 28x10.5's at 3200lbs
70 Challenger RT 440 4-speed 4:10 Dana
http://www.youtube.com/watch?v=VowFy4nDdfI
Re: foam for lift -off fiberglass hood... [Re: markz528] #360573
06/28/09 11:37 PM
06/28/09 11:37 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Joann's Fabrics
Thats where I got mine.
I used medium density foam and 3M spray adhesive to glue it on.
Post deleted by Defbob [Re: WILD BILL] #360574
06/29/09 12:14 AM
06/29/09 12:14 AM
Re: foam for lift -off fiberglass hood... #360575
06/29/09 06:52 AM
06/29/09 06:52 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I used 4 extra long bolts at the corners of my hood scoop. Then welded a big (2" or so) fender washer to a nut and put a 1/4" thick rubber chair foot on the washer. Works perfect to set on my roof.
Re: foam for lift -off fiberglass hood... [Re: racerAL] #360576
06/29/09 09:54 AM
06/29/09 09:54 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
Insulation foam that is used on water pipes and available at any home center. Cut and glue...I use construction glue.
Re: foam for lift -off fiberglass hood... #360577
06/29/09 10:47 AM
06/29/09 10:47 AM
Ohio
racerAL Offline OP
racerAL  Offline OP
Ohio
using these might be interesting
...lmao....could you imagine the looks i would get at the store when i pull them out of the package and perform a FEEL test...lol...that would be a hoot...
446 cid on E-85
best 60ft. 1.419
Re: foam for lift -off fiberglass hood... [Re: racerAL] #360578
06/29/09 10:59 AM
06/29/09 10:59 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
If you use those your car will need a bra.
Re: foam for lift -off fiberglass hood... [Re: racerAL] #360579
06/30/09 07:57 AM
06/30/09 07:57 AM
ohio
prochamp Offline
prochamp  Offline
ohio
check at your local body shop.body panels come shipped with dense lightweight rubber type blocks on the corners to protect them.even come in different colors.
Re: foam for lift -off fiberglass hood... [Re: prochamp] #360580
06/30/09 09:21 AM
06/30/09 09:21 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
My only problem with the foam blocks is...are they fireproof? Some are some are not. That's why I made mine like I did.
