Kickdown question #360123
06/27/09 11:18 PM
06/27/09 11:18 PM
Cincinnati,Ohio
P
paulgrr63 Offline OP
P
Cincinnati,Ohio
I installed a 4bbl Holley 570 carb on my 318(originally 2bbl). I bought Holley p/n 20-7 and 20-36 since the manual said I would need it for a Chrysler application. http://www.summitracing.com/parts/HLY-20-7/ and http://www.summitracing.com/parts/HLY-20-36/ The kickdown doesn't seem right. Does anyone have a pic of the kickdown linkage on a 4bbl carb? I drove it around and it wasn't shifting correctly. Any help would be appreciated. Paul
Re: Kickdown question [Re: paulgrr63] #360124
06/27/09 11:24 PM
06/27/09 11:24 PM
Renton, WA
GreenBlurr Offline
super gas
GreenBlurr  Offline
super gas
Renton, WA
Yes the bracket that bolts to the intake is a physicly different piece that puts the pivot and linkage in a different position on a 2 barrel rather than a 4 barrel.
Basicly all you need is that bracket itself. you can reuse the rest of the linkage parts. I might be able to dig up an example of both to show you the difference.
I also believe the 4 barrel one is reproduced. Mancini Racing sells them if I remember correctly.
Re: Kickdown question [Re: GreenBlurr] #360125
06/27/09 11:53 PM
06/27/09 11:53 PM
Cincinnati,Ohio
P
P
Cincinnati,Ohio
I checked with Mancini and they have a bracket but I already bought what the manual recommended(Holley p/n20-7 and stud 20-36) I would like to use the one that I bought but If i have to I will get Mancini's bracket.
Re: Kickdown question [Re: paulgrr63] #360126
06/28/09 12:09 AM
06/28/09 12:09 AM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
I just did the same swap almost, but I used an Eddy carb instead.
I found a four barrel braket at the junk yard.
two barrel on the left and 4 barl on the right, it is almost the same but about 3/8" taller. However, my kickdown linkage was still about 2" inches short.
note how the pivot shaft is not straight up and down. Today I made an extension out of the other kickdown shaft, and it works great. Sorry no pic, I can get one tomorrow if you need it.
My Monster are real!
Living within your means makes life pretty easy.
Re: Kickdown question [Re: 67vertman] #360127
06/28/09 12:18 AM
06/28/09 12:18 AM
Cincinnati,Ohio
P
P
Cincinnati,Ohio
If you can a pic of the extension would be great. Thank you for your help. Anybody else have any input?
Re: Kickdown question [Re: paulgrr63] #360128
06/28/09 12:28 AM
06/28/09 12:28 AM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Will do......
Re: Kickdown question [Re: 67vertman] #360129
06/28/09 12:35 AM
06/28/09 12:35 AM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Here you go....
I hope it helps.
Re: Kickdown question [Re: 67vertman] #360130
06/28/09 12:39 AM
06/28/09 12:39 AM
Cincinnati,Ohio
P
P
Cincinnati,Ohio
Here you go....
I hope it helps.
Ok I see what you did there. Looks like I will be going to the junk yard Monday. Thanks again Paul
