Dominator throttle cable mounts #359899
06/27/09 07:02 PM
06/27/09 07:02 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
I was considering just running a solid link from my pedal to the carb via rod ends and linkage. What are you guys running with a cable for a bracket to save me some time.
Gus
64 Plymouth Savoy
Dana 60
Re: Dominator throttle cable mounts [Re: fourgearsavoy] #359900
06/27/09 07:19 PM
06/27/09 07:19 PM
Vallejo California
T748 Offline
super street
T748  Offline
super street
Vallejo California
If your not running a drop base air cleaner,Summit or Jeg's sell some good looking ones. I had to make one to fit under the K&N drop base and mount an idle compensator. It's just 3/4" or 1" flat steel with the cable hold down from a stock bracket. -Tom.
Re: Dominator throttle cable mounts [Re: T748] #359901
06/27/09 07:37 PM
06/27/09 07:37 PM
Rittman Ohio
Rittman Ohio
Wow! an actual Team-G intake in use I have one of these intakes that I cant sell to anyone. I was going to use it but I got a great deal on a Mopar M-1 intake instead.I think I will just make a bracket like yours to use the factory cable just to save time and money
Gus
64 Plymouth Savoy
Dana 60
Re: Dominator throttle cable mounts [Re: fourgearsavoy] #359902
06/27/09 08:20 PM
06/27/09 08:20 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I got a bracket,,,and a lokar cable,,,dont have any close up pics............
Previous set up with the stock cable and attachements,,,always seemed to move,,and was actually not opening the carb all the way....
I like the current setup,,,works great,,,no worries...
Re: Dominator throttle cable mounts [Re: fourgearsavoy] #359903
06/27/09 08:59 PM
06/27/09 08:59 PM
AndyF Offline
AndyF  Offline
I make throttle brackets (and throttle returns) that work with Dominator carbs. Mancini should have them in stock or try Hughes, they also carry most of my stuff these days. My stuff is designed to work with stock throttle cables. There is also a tab on there for a Lokar kickdown but I've never seen anyone hook up a kickdown to a Dominator carb before. It is possible to do, just never seen it done.
Re: Dominator throttle cable mounts [Re: AndyF] #359904
06/27/09 09:18 PM
06/27/09 09:18 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I have the Mancin bracket on my 440 with M1 and Dominator.I used a /6 cable and modified the pedal end to fit the 65 setup.Works fine and its street driven.Rocky
Chrysler Firepower
Re: Dominator throttle cable mounts [Re: therocks] #359905
06/27/09 09:35 PM
06/27/09 09:35 PM
PA
moparacer Online content
moparacer  Online Content
PA
I bought the Jegs cable mount and return spring bracket for mine. Similar to what 69 has in his pic.
With the 2 ft lokar cable it is sweet....
I will take a pic and post it.
was only like $59
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Dominator throttle cable mounts [Re: moparacer] #359906
06/27/09 09:44 PM
06/27/09 09:44 PM
PA
PA
I had to use 2 5/16 flat washers under the bracket to give the accelerator pump arm adequate clearance....
Re: Dominator throttle cable mounts [Re: moparacer] #359907
06/27/09 09:46 PM
06/27/09 09:46 PM
PA
PA
another
Re: Dominator throttle cable mounts [Re: moparacer] #359908
06/27/09 11:40 PM
06/27/09 11:40 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
moroso return spring and csr throttle bracket
1.39 9.85 - 137 mph
Re: Dominator throttle cable mounts [Re: Ari440] #359909
06/28/09 01:07 AM
06/28/09 01:07 AM
Uppsala, Sweden
Satanized_68 Offline
Uppsala, Sweden
I have a Jeg's throttle bracket and I think it's a nice piece. Fits perfect under my 16" drop base K&N air cleaner.
I did have to put a small notch in the back (see pic) but that's no biggie, 5sec job max.
Getting closer... <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: Dominator throttle cable mounts [Re: fourgearsavoy] #359910
06/28/09 02:03 AM
06/28/09 02:03 AM
Vallejo California
T748 Offline
super street
T748  Offline
super street
Vallejo California
Gus
Thats funny, I've got an M1 4500 that nobody wants. One of these days I'll bring both to the track for a back to back test. My engine builder claimed the G made more power but I don't have any paper nor given numbers to prove it.
Andy F's throttle brackets are great deals. I had one with a victor/4150 combo and it was sweet! I would reccomend anything that comes from his shop.
-Tom.
Re: Dominator throttle cable mounts [Re: fourgearsavoy] #359911
06/28/09 08:37 AM
06/28/09 08:37 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
I use a solid shaft and was told be a tech guy I needed to have a toe clip welded to the pedal Which I've forgot to do until right now .
Also a solid throttle stop for the pedal to rest on @ WOT.
Re: Dominator throttle cable mounts [Re: T748] #359912
06/28/09 10:58 AM
06/28/09 10:58 AM
Rittman Ohio
Rittman Ohio
Gus
-Tom.
Yeah I think I will go with Andy's bracket to keep my original cable and be able to use my K&N air filter.
I had that Team-G at a swap meet before and the best offer I had was $60.00 so I took it back home.
Gus
64 Plymouth Savoy
Dana 60
Re: Dominator throttle cable mounts [Re: fourgearsavoy] #359913
06/28/09 11:58 AM
06/28/09 11:58 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
Put the Team G on ebay if you want to sell it. I sold one a while back (dominator flange for RB), had several bids on it. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Dominator throttle cable mounts [Re: AndyF] #359914
06/28/09 05:56 PM
06/28/09 05:56 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
I use this on my charger with a $20.00 stock cable and it works great.
