Page 4 of 4 1 2 3 4
Re: 70 Chall flip top, locking gas cap color? [Re: Alaskan_TA] #359593
07/07/09 11:44 PM
07/07/09 11:44 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
page 14-60A for the 1970-71 Chrysler Parts Catalog
Re: 70 Chall flip top, locking gas cap color? [Re: 6bblgt] #359594
07/07/09 11:47 PM
07/07/09 11:47 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
readable1
Re: 70 Chall flip top, locking gas cap color? [Re: 6bblgt] #359595
07/07/09 11:48 PM
07/07/09 11:48 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
2
Re: 70 Chall flip top, locking gas cap color? [Re: 6bblgt] #359596
07/07/09 11:49 PM
07/07/09 11:49 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
3
Re: 70 Chall flip top, locking gas cap color? [Re: 6bblgt] #359597
07/08/09 12:03 PM
07/08/09 12:03 PM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
"gygeneral's What's up with these two holes"
Well I took the rubber out, and those two holes are vented to two little openings, that would be outside of the rubber seal. See pic. Now, what does this mean? Is this one of those vented caps. Dont's forget the bottom of the cap says "pressure vacuum".
On a side note, what happens if you put a vented cap on when it should be a non-vented cap.
Re: 70 Chall flip top, locking gas cap color? [Re: gygeneral] #359598
07/08/09 12:46 PM
07/08/09 12:46 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I've edited some of my earlier posts, I had the caps bass ackwards!
Most 1970 model Challengers were non-E.C.S. and would use the "NOT VENTED" locking gas cap. This sealed gas cap would prevent gas from exiting the tank. The gas tank was "vented" to atmosphere by other means.
1970 model Challengers with "N95" and all 1971 models would use the "PRESSURE/VACUUM" locking gas cap. This gas cap would allow air to escape under pressure or enter under vacuum conditions. The gas caps on the E.C.S. (basically - sealed fuel systems) equipped were the "safety valve" for (excessive?) pressure or vacuum.
Re: 70 Chall flip top, locking gas cap color? [Re: 6bblgt] #359599
07/08/09 06:21 PM
07/08/09 06:21 PM
Soldotna,Alaska
RT_6_PakShaker Offline
super street
super street
Soldotna,Alaska
Anybody know how the two pieces of "pot-metal" can be removed from the "chromed" steel piece?
6bbl
try using a small flat screw driver and work carefully prying between the pot metal top or bottom and steel center piece, also you can try grabbing the pot metal pieces and try rocking back and for in opposite directions to get them to part from the center.
I have taken several apart for replating this way.
Re: 70 Chall flip top, locking gas cap color? [Re: RT_6_PakShaker] #359600
07/08/09 10:11 PM
07/08/09 10:11 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: 70 Chall flip top, locking gas cap color? [Re: Alaskan_TA] #359601
07/08/09 11:03 PM
07/08/09 11:03 PM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
Info on the 1970 ECS System, (N95 option code)
the pressure / vacuuum cap is mentioned at the second link, but I did not want to post it out of context.
http://www.hamtramck-historical.com/images/serviceHighlights/70%20sh%20125.jpg
http://www.hamtramck-historical.com/images/serviceHighlights/70%20sh%20126.jpg
http://www.hamtramck-historical.com/images/serviceHighlights/70%20sh%20127.jpg
Thanks , that's a good explanation of how that system functions. So I guess the two holes on my cap has somekind of valve in them ?? Maybe I have to go one step further and break the two halves apart and see what is there.
Re: 70 Chall flip top, LOCKING gas cap color/wont lock! [Re: 6pakdude] #2470990
03/23/18 03:37 PM
03/23/18 03:37 PM
IL
B5EBody Offline
B5EBody  Offline
IL
Put it in the parts for sale section. And no eBay links are allowed here.
Re: 70 Chall flip top, LOCKING gas cap color/wont lock! [Re: 6pakdude] #2875083
01/16/21 01:26 PM
01/16/21 01:26 PM
IL
B5EBody Offline
B5EBody  Offline
IL
If your Challenger locking cap dosen't lock, the problem is the locking tab on the disc shown in this thread is broken off. I have replacement discs I had manufactured for sale. I used one on mine and have sold a few more and they work beautifully. $20. Easy installation and cheap fix for a very expensive cap.
Page 4 of 4 1 2 3 4
