Need some help!!! #358856
06/26/09 05:52 PM
06/26/09 05:52 PM
Texas
68Chrgr Offline OP
68Chrgr  Offline OP
Texas
just had my engine rebuilt, runs great since I have installed the engine in the car when I accelerate thru first and make the shift into second when the rpm's drop the car like surges and wont accelerate. I have to let off the gas and then get back into the gas it slower.
What would cause it to do that?
Re: Need some help!!! [Re: 68Chrgr] #358857
06/26/09 06:39 PM
06/26/09 06:39 PM
Ya know, ya'd think a guy smart enough to rebuild an engine could think of a better thread title than "help."
Sounds to me like it's not getting fuel
Plugged pickup screen in tank
bad hose at tank to line, junk in line
bad hose at line--to pump
bad pump
plugged fuel filter.
So, I dunno, it's up to you
Buy a vacuum/ pressure gauge, cheap at any parts store, even a "fake" parts store
Hook to INLET of pump and idle engine long enough to read, see what the gauge reads. Should be substantial vacuum.
Replace both hoses in fuel line, as well as filter
How about carb float level, have you checked that? You been into the carb? Has it been sitting around?
Re: Need some help!!! #358858
06/26/09 07:11 PM
06/26/09 07:11 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Hey six, he said he HAD it rebuilt, man, sounds like it's a fuel issue to me too.
Re: Need some help!!! [Re: buildanother] #358859
06/27/09 12:02 AM
06/27/09 12:02 AM
Texas
68Chrgr Offline OP
68Chrgr  Offline OP
Texas
Thank you both for your input.
I am going to cheeck that all out.
Re: Need some help!!! #358860
06/27/09 01:23 AM
06/27/09 01:23 AM
MNobody Offline
MNobody  Offline
"Ya know, ya'd think a guy smart enough to rebuild an engine could think of a better thread title than "help."
And you would also think a guy with all the answers could read....He said he just had it rebuilt not that he rebuilt it
Re: Need some help!!! [Re: MNobody] #358861
06/27/09 01:26 AM
06/27/09 01:26 AM
North Chicagoland
N
newbee69 Offline
newbee69  Offline
N
North Chicagoland
Id put money on the pump. But change out the hoses and filter first. Also check float level.
Re: Need some help!!! [Re: newbee69] #358862
06/27/09 01:33 AM
06/27/09 01:33 AM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Maybe you should try to diagnose the problem first, is fuel pressure dropping off?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Need some help!!! [Re: MNobody] #358863
06/27/09 12:46 PM
06/27/09 12:46 PM
Do you work for Microsoft? I'm just wondering, because, while your answer was technically correct, it really wasn't very helpful
Re: Need some help!!! #358864
06/30/09 08:23 AM
06/30/09 08:23 AM
Texas
68Chrgr Offline OP
68Chrgr  Offline OP
Texas
Fuel pump is brand new. I did not change out the fuel lines to the pump, or the tank. The tank has a rather large dent (equivalent to maybe 3 or 4 gallons), And I just noticed that it is leaking also. Not sure if that would add to the problem or not. Carb is brand new as well.
Re: Need some help!!! [Re: 68Chrgr] #358865
06/30/09 08:35 AM
06/30/09 08:35 AM
rig a small gas can in the eng compartment hooked to the pump inlet w some 5/16"neoprene fuel line & take her out again. This'll tell you if the prob is in the rear line/tank/pickup or if it's forward from the there including the pump(including the eccentric,(pushrod if BB) and/or the carb(needle/seat/float level/filter).
Re: Need some help!!! [Re: RapidRobert] #358866
06/30/09 10:36 AM
06/30/09 10:36 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Could be the dented area is at the pick up tube which is now bent or closed off causing a lack of fuel flow.
