industrial 413 #357773
06/25/09 05:20 PM
06/25/09 05:20 PM
ohio
2
2young2drive Offline OP
ohio
I am building an industrial 413 for a ramcharger that will be mostly an off road toy. My real question is what would you motor guru's do with this motor to get it a little more to date? This was a complete motor with only 22,000 miles on it. I also have a complete 383 motor at my disposal in my garage(use those heads?) I was thinking new pistons to get some more compression dispite the lack of being able to find some really. All info is appreciated and thanked
Andrew
Re: industrial 413 [Re: 2young2drive] #357774
06/25/09 05:27 PM
06/25/09 05:27 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
A newbie ...today !! ...welcome ...
You see that avatar-pic of that MH ? .. that 413 is one of MY projects.
IF you do not plan on rpming the motor more than 4,000 or so ... it is the best piece you can get. But I would UPgrade the compression, cam and fuel delivery. And KEEP those heads.
What is your budget ?
Re: industrial 413 [Re: dOOc] #357775
06/25/09 05:35 PM
06/25/09 05:35 PM
ohio
2
ohio
Yes sir, I've been looking for awhile for a Mopar site. My budget will be however much i need to get it running right. Compression is my number one priority. I'm just having trouble with getting it... By saying to keep the heads do you mean to stick with the huge water pump assembly too? I'm looking to make this motor rather torquey as it will be hauling around a 7000lb truck. Any cam input?
Andrew
Re: industrial 413 [Re: 2young2drive] #357776
06/25/09 05:50 PM
06/25/09 05:50 PM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
Your budget ...to spend maybe 1k$ for pistons? ....How much compression do you want ? .... the OEM "industrial" 413 has a pathetic feeble compression ratio. Some who have actually run the figures say it is closer to 6.5 than it is to 7 to 1.
My initial plans are to set this motor up to pull as much as 19,000 lbs ...and run premium fuel - if I have to. YES ..I am talking about using those-heads with that huge water-pump. Those heads are KILLER for a tow-rig.
Cam ? ... I am still collating on that. I am considering a hyd roller - high-lift, fast-rate cam .. but my concerns are valve-spring life.
Re: industrial 413 [Re: dOOc] #357777
06/25/09 06:12 PM
06/25/09 06:12 PM
ohio
2
ohio
Well for compression I am aiming for anywhere around 9-10:1. If it goes higher that's perfectly fine with me, as long as it is still within a reliable state.
Inside of my heads, there are little wires in where the water flows through. are these normal for these heads?? just seems like a no no. And i have no idea how they got in there. I can get pictures as well.
Where are you seeing some pistons? http://www.hughesengines.com/Index/produ...mp;partid=24537
These are what I've found so far for pistons. Any good?
Andrew
Re: industrial 413 [Re: 2young2drive] #357778
06/25/09 06:33 PM
06/25/09 06:33 PM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
I don't think that you can get more than middle 8's or so compression ratio with the flat-top pistons. Most of the blocks have a fat-deck-spec and if you clean the comp chambers up ... you pick-up major CC's there.
Those wires ? ...are in every head I have seen. It maybe has got to do with something like the "electroylis" process ??
Re: industrial 413 [Re: 2young2drive] #357779
06/25/09 06:48 PM
06/25/09 06:48 PM
iowa
copchaser Offline
copchaser  Offline
iowa
I pulled a 413 from a motorhome and dropped it in a 93 RAM, hung a truck 4-speed behind it. I rigged up a turbo off of a diesel semi on it, it woke it up big time. Cheap and very easy.
Re: industrial 413 [Re: copchaser] #357780
06/25/09 07:33 PM
06/25/09 07:33 PM
ohio
2
ohio
have any pictures? would you like to give a little more info on how and where you put the turbo in? I've been getting a few people telling me to turbo this motor. just seeing how difficult this was for you
Andrew
Re: industrial 413 [Re: copchaser] #357781
06/25/09 09:21 PM
06/25/09 09:21 PM
lewiston, ID
cornucopia Offline
cornucopia  Offline
lewiston, ID
wow! cheap and super cool! you must post some pics...
Re: industrial 413 [Re: cornucopia] #357782
06/25/09 10:21 PM
06/25/09 10:21 PM
qc
mxbeep Offline
mxbeep  Offline
qc
the wires inside your head are problably from they were poored at the factory.
The sand molds were held together with metal wires
Re: industrial 413 [Re: mxbeep] #357783
06/27/09 12:16 AM
06/27/09 12:16 AM
ohio
2
ohio
BTT!!!
