400 Oil Pressure question
#357030
06/24/09 07:29 PM
06/24/09 07:29 PM
Posts: 1,037 Texas, Dallas
G_T
Texas, Dallas
1977 400, about 105K miles on it. Engine runs fine, no knocks, weird noises, etc. Mechanical oil gage.
2 months ago, it had 65-70psi cold, and ~30psi hot, ~10psi idle.
It has slowly dropped since. Did the usual oil changes (10W-40) and oil filter (puralator).
Now it is ~40psi cold, and ~5-10psi hot, 0psi at idle.
The top end was rebuilt about a year ago (head work, cam, manifold, etc.).
I'm not sure if the engine is just worn, or if a replacement oil pump is in order.
Other than leaking oil, it doesn't seem to burn/smoke.
Any harm with installing a high vol pump?
Other suggestions?
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com
2012 Charger SRT8
Re: 400 Oil Pressure question
[Re: dOOc]
#357033
06/24/09 07:48 PM
06/24/09 07:48 PM
G_T
Texas, Dallas
last oil change was 2K ago. Pan was pulled the same time we did the top end to change gaskets and rear main seal. Nothing in the pan at that time (Actually I was surprised as it had the stock nylon timing set which we replaced with a dbl roller set at the time).
Engine was very clean inside - no crud/etc.
I guess a $65 high vol pump isn't a bad investment - very easy to change. Just seems odd that a pump would slowly go away like that over a 6 month period of time...
2012 Charger SRT8
[Re: G_T]
#357034
06/24/09 07:52 PM
06/24/09 07:52 PM
Posts: 30,460 Florida STAYcation
dOOc
The village idiot's idiot
Florida STAYcation
THAT is very odd ...I would put another gauge on it to double-check the psi.
[Re: dOOc]
#357035
06/24/09 07:56 PM
06/24/09 07:56 PM
Pump is fine drive it until it pukes Yea ..maybe the cam bearings have gone away maybe maybe maybe this maybe that--drive it! Have fun! when it quits THEN fix it--save that oil pump $$ for a tank of gas--
[Re: dOOc]
#357036
06/24/09 07:57 PM
06/24/09 07:57 PM
Posts: 2,179 S.E. Conn
Hoof Hearted
S.E. Conn
Free advice from experience, cheap enough to do.
1) Replace oil pump with a Melling Hi-VOLUME (not pressure)
2) go with at least a 10/40 (I like Rotella 15/40)
3) Use a Napa Gold oil filter
4) consider changing the oil pump Input Shaft to a Mopar Perf. HARDENED Shaft.
2005 300C Hemi 2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
[Re: ]
#357037
06/24/09 07:59 PM
06/24/09 07:59 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
and carry plenty of freinds to push when it fails. I say check with a mechanical guage and make sure of your pressure befor anything else. If your bearings are wiped out, a new pump wont do anything. you could try thicker oil and see what that does for you.
[Re: Hoof Hearted]
#357038
06/24/09 10:23 PM
06/24/09 10:23 PM
G_T
Texas, Dallas
Thanks Hoof... that is what I was planning. I really don't think it's the oil pressure gage...but, I can get another one to validate.
Worse case - if it blows, I have a spare 400 in the garage
2012 Charger SRT8
[Re: G_T]
#357039
06/24/09 10:27 PM
06/24/09 10:27 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
Very good plan. This is actually what a hi volume oil pump was designed for. To restore pressure in engines with bigger clearance.
[Re: G_T]
#357041
06/24/09 10:29 PM
06/24/09 10:29 PM
G_T
Texas, Dallas
I thought the shaft on a big-block is integral to the distributor cam gear? I thought you only went with the hardened (bronze gear?) if you had a roller cam? Or am I off?
2012 Charger SRT8
[Re: stumpy]
#357043
06/24/09 10:33 PM
06/24/09 10:33 PM
G_T
Texas, Dallas
No reason to at the time (12 months ago). Everything was fine. Motor ran strong, zero issues other than the leaking rear main seal. Engine only had ~70K on it at the time.
2012 Charger SRT8
[Re: G_T]
#357045
06/24/09 11:29 PM
06/24/09 11:29 PM
Hoof Hearted
S.E. Conn
Quote: "I thought the shaft on a big-block is integral to the distributor cam gear? I thought you only went with the hardened (bronze gear?) if you had a roller cam? Or am I off?"
Yeah, you're a little off; Mopar Perf. makes an input shaft with a Forged(?) HARDENED End. With the heavier oil and volume of flow comes more of a chance you'll round off the tip, as we've all done with allen wrenches ...
The gear end stays the same.
*UPDATE* 400 Oil Pressure question
[Re: Hoof Hearted]
#357046
07/14/09 01:28 AM
07/14/09 01:28 AM
G_T
Texas, Dallas
Well the bandaid seemed to work. Swapped out the oil pump for a high vol unit, checked gage, new filter/oil & shaft as stated above. Primed it and fired it up. 75psi cold 25psi hot idle @ 195 degrees and 700 rpm I'm sure it's a matter of time before a rebuild, but this seems to have cured it for a bit. Just a waiting game - so I can have some fun for a while. I'll post again if/when a tap or knock develops Btw, removing the oil pump shaft for priming/replacement was real fun (NOT). Did it with the manifold on - made a little tool to grab the gear and pull it out the distributor hole.
2012 Charger SRT8
[Re: RapidRobert]
#357048
07/14/09 12:25 PM
07/14/09 12:25 PM
Posts: 2,256 IL
furious70
IL
oil psi dropped out of the blue after racing 2 yrs ago in the 383 in my Fury, put a new pump on and it went back to normal and has been fine since. I did not tear down the old pump to diagnose, was happy it was fixed.
70 Sport Fury 68 Charger 69 Coronet 72 RR
