400 Oil Pressure question #357030
06/24/09 07:29 PM
06/24/09 07:29 PM
Texas, Dallas
G_T Offline OP
G_T  Offline OP
Texas, Dallas
1977 400, about 105K miles on it. Engine runs fine, no knocks, weird noises, etc. Mechanical oil gage.
2 months ago, it had 65-70psi cold, and ~30psi hot, ~10psi idle.
It has slowly dropped since. Did the usual oil changes (10W-40) and oil filter (puralator).
Now it is ~40psi cold, and ~5-10psi hot, 0psi at idle.
The top end was rebuilt about a year ago (head work, cam, manifold, etc.).
I'm not sure if the engine is just worn, or if a replacement oil pump is in order.
Other than leaking oil, it doesn't seem to burn/smoke.
Any harm with installing a high vol pump?
Other suggestions?
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com 2012 Charger SRT8
Re: 400 Oil Pressure question [Re: G_T] #357031
06/24/09 07:34 PM
06/24/09 07:34 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Pumps are an easy change. Better to be safe then sorry
Re: 400 Oil Pressure question [Re: G_T] #357032
06/24/09 07:36 PM
06/24/09 07:36 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
With all those oil-changes .. you might have loosened up some crud in-the-pan and elsewhere and it is now restricting the pick-up tube and screen.
Pull the pan.
Re: 400 Oil Pressure question [Re: dOOc] #357033
06/24/09 07:48 PM
06/24/09 07:48 PM
Texas, Dallas
G_T Offline OP
G_T  Offline OP
Texas, Dallas
last oil change was 2K ago. Pan was pulled the same time we did the top end to change gaskets and rear main seal. Nothing in the pan at that time (Actually I was surprised as it had the stock nylon timing set which we replaced with a dbl roller set at the time).
Engine was very clean inside - no crud/etc.
I guess a $65 high vol pump isn't a bad investment - very easy to change. Just seems odd that a pump would slowly go away like that over a 6 month period of time...
Re: 400 Oil Pressure question [Re: G_T] #357034
06/24/09 07:52 PM
06/24/09 07:52 PM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
THAT is very odd ...I would put another gauge on it to double-check the psi.
Re: 400 Oil Pressure question [Re: dOOc] #357035
06/24/09 07:56 PM
06/24/09 07:56 PM
Pump is fine
drive it until it pukes
Yea ..maybe the cam bearings have gone away
maybe maybe maybe this maybe that--drive it! Have fun! when it quits THEN fix it--save that oil pump $$ for a tank of gas--
Re: 400 Oil Pressure question [Re: dOOc] #357036
06/24/09 07:57 PM
06/24/09 07:57 PM
S.E. Conn
Hoof Hearted Offline
S.E. Conn
Free advice from experience, cheap enough to do.
1) Replace oil pump with a Melling Hi-VOLUME (not pressure)
2) go with at least a 10/40 (I like Rotella 15/40)
3) Use a Napa Gold oil filter
4) consider changing the oil pump Input Shaft to a Mopar Perf. HARDENED Shaft.
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: 400 Oil Pressure question [Re: ] #357037
06/24/09 07:59 PM
06/24/09 07:59 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Pump is fine
and carry plenty of freinds to push when it fails.
I say check with a mechanical guage and make sure of your pressure befor anything else. If your bearings are wiped out, a new pump wont do anything. you could try thicker oil and see what that does for you.
Re: 400 Oil Pressure question [Re: Hoof Hearted] #357038
06/24/09 10:23 PM
06/24/09 10:23 PM
Texas, Dallas
G_T Offline OP
G_T  Offline OP
Texas, Dallas
Thanks Hoof... that is what I was planning. I really don't think it's the oil pressure gage...but, I can get another one to validate.
Worse case - if it blows, I have a spare 400 in the garage
Re: 400 Oil Pressure question [Re: G_T] #357039
06/24/09 10:27 PM
06/24/09 10:27 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Very good plan. This is actually what a hi volume oil pump was designed for. To restore pressure in engines with bigger clearance.
Re: 400 Oil Pressure question [Re: G_T] #357040
06/24/09 10:28 PM
06/24/09 10:28 PM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
SAVE your money on a new oil pump ! .... I have taken apart enough motors to see pumps that look totally grim ... put out pressure just fine.
But if your gauge swap confirms low pressure ... just put a couple of washers in with that relief spring IN the pump you have.
Re: 400 Oil Pressure question [Re: G_T] #357041
06/24/09 10:29 PM
06/24/09 10:29 PM
Texas, Dallas
G_T Offline OP
G_T  Offline OP
Texas, Dallas
I thought the shaft on a big-block is integral to the distributor cam gear? I thought you only went with the hardened (bronze gear?) if you had a roller cam? Or am I off?
Re: 400 Oil Pressure question [Re: dOOc] #357042
06/24/09 10:31 PM
06/24/09 10:31 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Why didn't you check a rod bearing or two when you had the pan off? It takes 10 minutes and doesn't cost a dime. 105k miles you are ready for a rebuild. I don't think a new oil pumnp will do you any good at all.
Re: 400 Oil Pressure question [Re: stumpy] #357043
06/24/09 10:33 PM
06/24/09 10:33 PM
Texas, Dallas
G_T Offline OP
G_T  Offline OP
Texas, Dallas
No reason to at the time (12 months ago). Everything was fine. Motor ran strong, zero issues other than the leaking rear main seal. Engine only had ~70K on it at the time.
Re: 400 Oil Pressure question [Re: G_T] #357044
06/24/09 10:37 PM
06/24/09 10:37 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
No reason not to while the pan is already off.` I check mine every time I pull the pan. Like I said it's free and never hurts to know whats going on in the lower end.
Re: 400 Oil Pressure question [Re: G_T] #357045
06/24/09 11:29 PM
06/24/09 11:29 PM
S.E. Conn
S.E. Conn
Quote: "I thought the shaft on a big-block is integral to the distributor cam gear? I thought you only went with the hardened (bronze gear?) if you had a roller cam? Or am I off?"
Yeah, you're a little off; Mopar Perf. makes an input shaft with a Forged(?) HARDENED End. With the heavier oil and volume of flow comes more of a chance you'll round off the tip, as we've all done with allen wrenches ...
The gear end stays the same.
2005 300C Hemi
*UPDATE* 400 Oil Pressure question [Re: Hoof Hearted] #357046
07/14/09 01:28 AM
07/14/09 01:28 AM
Texas, Dallas
G_T Offline OP
G_T  Offline OP
Texas, Dallas
Well the bandaid seemed to work. Swapped out the oil pump for a high vol unit, checked gage, new filter/oil & shaft as stated above. Primed it and fired it up.
75psi cold
25psi hot idle @ 195 degrees and 700 rpm
I'm sure it's a matter of time before a rebuild, but this seems to have cured it for a bit. Just a waiting game - so I can have some fun for a while.
I'll post again if/when a tap or knock develops
Btw, removing the oil pump shaft for priming/replacement was real fun (NOT). Did it with the manifold on - made a little tool to grab the gear and pull it out the distributor hole.
Re: 400 Oil Pressure question [Re: G_T] #357047
07/14/09 09:41 AM
07/14/09 09:41 AM
yes the bronze gear one is for a roller cam & the hardened tip one is a regular one for non roler cams but has a hardened hex end
Re: 400 Oil Pressure question [Re: RapidRobert] #357048
07/14/09 12:25 PM
07/14/09 12:25 PM
IL
furious70 Offline
furious70  Offline
IL
oil psi dropped out of the blue after racing 2 yrs ago in the 383 in my Fury, put a new pump on and it went back to normal and has been fine since. I did not tear down the old pump to diagnose, was happy it was fixed.
70 Sport Fury
68 Charger
69 Coronet
72 RR
