Page 3 of 5 1 2 3 4 5
Re: w5 dyno [Re: cheapstreetdustr] #35443
01/11/08 06:16 PM
01/11/08 06:16 PM
Greenville, SC
bad360rt Offline
bad360rt  Offline
Greenville, SC
That's a bad 408 right there.
Can't wait to see what kind of power my W5's make.
Re: w5 dyno [Re: bad360rt] #35444
01/08/10 09:19 AM
01/08/10 09:19 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Digging through some more old stuff............
Did this car make any passes yet?
Re: w5 dyno [Re: S/ST 3040] #35445
01/08/10 09:54 AM
01/08/10 09:54 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
nice #'s arc!
didn't anyone HERE tell you it is impossible to make 700+hp with a 59* sb??
Re: w5 dyno [Re: RyanJ] #35446
01/08/10 10:20 AM
01/08/10 10:20 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
I'll be looking forward to see what the car does this year once get some real 1/4 passes on it. Sounds like need to pull some gear out of it.
Ryan, if the engine is up to it (valvetrain), maybe leave the gear and move the chip.
7800 isn't even 500 over peak and it looks like it holds on pretty good on the sheet.
Crossing 800-1000 over peak might produce the best ET.
What do ya think???
Re: w5 dyno [Re: jim sciortino] #35447
01/08/10 10:30 AM
01/08/10 10:30 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
What do ya think???
I just ported the heads & did the machining on the heads.... So I don't have alot of input on it.. ARC built it & it's owned by another guy in LI...
As far as I know it's never been back to track after licensing passes, but I hav'nt asked anyone about it, so that could be wrong. I think it went back to ARC's shop to get ladder barred? or More tire or something done in rear suspension..... I was told the race weight @ one time but I do not remember what it was, I want to say it is fairly light, under 3000 race weight, but again, that is going off of something I was told probably 2 years ago.... my memory is not THAT good. I know ARC is still popping around here a little as he just PM'd me the other day so maybe Alan will see this & chime in.
My opinion on orig question would be..... That thing has steel valves in it, & probably 8000-8100 would be about as high as I'd want to turn it.
Re: w5 dyno [Re: StrokerAspen] #35448
01/08/10 10:58 AM
01/08/10 10:58 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Nice job on the heads How much of a PITA was angle milling the 2*?
Re: w5 dyno [Re: emarine01] #35449
01/08/10 11:22 AM
01/08/10 11:22 AM
NJ
arc Offline OP
arc  Offline OP
NJ
we got the car out in oct for a t&t it went 9.50s but with a good 60 1.24 Carl is a new racer so some of the passes he lifted but it runs good no popping there are other things 2 work out on the car The trans is spraying fluid all over and is spining on the the gear change from 1 to 2 The car has a 904 that i did not wont it needs a powerglide but what do i know so i think it runs ok but is .3 to .4 off for power it made I did a 4link in the car with carbon tubs & int it looks very nice
Re: w5 dyno [Re: arc] #35450
01/08/10 11:29 AM
01/08/10 11:29 AM
NJ
arc Offline OP
arc  Offline OP
NJ
one other thing we still have not made a pass with the vacuum pump on it made 26 more hp with it
Re: w5 dyno [Re: arc] #35451
01/08/10 03:56 PM
01/08/10 03:56 PM
Minnesota
Coldart Offline
Coldart  Offline
Minnesota
what w5 intake used small or large runner?
Re: w5 dyno [Re: Coldart] #35452
01/08/10 07:25 PM
01/08/10 07:25 PM
NJ
arc Offline OP
arc  Offline OP
NJ
large runner 4500
Re: w5 dyno [Re: arc] #35453
05/17/10 12:48 AM
05/17/10 12:48 AM
NJ
arc Offline OP
arc  Offline OP
NJ
just a update if any one cares i got a pass in the car today karl had a bad day he didn't a good pass all day so i got in it late it went 9.37 at 144.77 we got some more work but were getting there
Re: w5 dyno [Re: arc] #35454
05/17/10 01:24 AM
05/17/10 01:24 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
thats one quick small block
Re: w5 dyno [Re: arc] #35455
05/17/10 04:32 AM
05/17/10 04:32 AM
Alberta, Can
JUST_N_TIME Offline
JUST_N_TIME  Offline
Alberta, Can
we w5 headed engines care for sure - keep us updated - way to go.
Re: w5 dyno [Re: JUST_N_TIME] #35456
05/17/10 07:47 AM
05/17/10 07:47 AM
Shelby Twp. Mi
HardcoreB Online content
HardcoreB  Online Content
Shelby Twp. Mi
Wow...impressive! Thanks for the update.
Re: w5 dyno [Re: arc] #35457
05/17/10 07:57 AM
05/17/10 07:57 AM
S/ST 3040 Offline
S/ST 3040  Offline
Alan.......that's a good running W-5. What's the race weight?
Re: w5 dyno [Re: S/ST 3040] #35458
05/17/10 08:02 AM
05/17/10 08:02 AM
NJ
arc Offline OP
arc  Offline OP
NJ
2750 with me in it 2690 with karl
Re: w5 dyno [Re: arc] #35459
05/17/10 08:30 AM
05/17/10 08:30 AM
S/ST 3040 Offline
S/ST 3040  Offline
I know the Moroso Power/Speed calculator don't correlate to most
dynos but, I get 670 HP on that package.........and that's on the
high end of the W-5 scale compared to most.
Re: w5 dyno [Re: S/ST 3040] #35460
05/17/10 09:24 AM
05/17/10 09:24 AM
NJ
arc Offline OP
arc  Offline OP
NJ
I think that is 670 rear wheel hp . I know it will go 9 teens now i was on the chip more then i was off it the air shifter broke so we had to shift it are self lets just say iam out of practice on shifting a 3 speed . we will make some changes and get back out there
Re: w5 dyno [Re: arc] #35461
05/17/10 09:53 AM
05/17/10 09:53 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
What block are you using?
Re: w5 dyno [Re: cheapstreetdustr] #35462
05/17/10 01:27 PM
05/17/10 01:27 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
that motor is still pulling....too...
those are some serious numbers for a 408"
close to 2hp @ cube...
Hey Ryan..do you remember me saying about 5 yrs ago..that w-5's were where its at?
You certainly seem to have those puppies figured out...
if you could get them re-popped ..? that would be sweet..
then we could ditch the 360-1 /2's
i wish i had more money to spend.
cheaspt.
this 368" W-5 made 511hp 468 fttq should have never let it get away..
but the exhaust ports didnt look like yours
cheapst.
done right those w-5's are Freeks...
your dreams may come true from what i know.
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
