M/T ET Street tire question
#354509
06/22/09 11:23 AM
06/22/09 11:23 AM
Posts: 326 Davenport, IA
70shaker
Davenport, IA
Just mounted a set of 275-60 ET Streets on my Challenger and I am going to run it down the track soon. I do not have tubes. This is the first time on the track in 20 plus years. Do I need to screw these to the rims?
What is a good starting point for tire pressure? Also what is a good or safe range to run these tires?
Car is 70 Challenger. 472 hemi on pump gas, 4 speed, 4:30 gears.
Ex Hemi Racer 70 Challenger Hemi 4 speed clone
Re: M/T ET Street tire question
[Re: 70shaker]
#354510
06/22/09 11:26 AM
06/22/09 11:26 AM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
I'd start with 17 psi and go UP from there. If it hooks hard it will most likely spin the rim inside the tire a little, but screws are not mandatory. If the track is good, I will run 19.5 to 20 psi in mine, although I'm running the bigger 295-65 radials. I have been almost as fast on the 275-60's though. CHIP
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: 70shaker]
#354511
06/22/09 11:27 AM
06/22/09 11:27 AM
Triple Threat
Renton Washington
Are these the Radial or Bias ply Version? If they're radial, you don't use tubes.
[Re: 70shaker]
#354513
06/22/09 11:39 AM
06/22/09 11:39 AM
I run 15 lbs in mine,she seems to like it there best, i started at 20 and made my way down others at the track run the same pressure..
[Re: 70shaker]
#354514
06/22/09 12:08 PM
06/22/09 12:08 PM
Posts: 43,719 Bend,OR USA
Cab_Burge
The ET Street Radail may not be the best street strip tire for your car due to the 4 speed I don't know which one would be better, sorry. I do run the MT 315x60x15 on my car and have found that no two tire gauges are exactly the same, I use the same gauge now and run 18 to 22 lbs depending on the track I'm at Buy a good gauge and try different pressures to find out what your car wants
[Re: 70shaker]
#354515
06/22/09 12:26 PM
06/22/09 12:26 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I didn't screw mine. But then again the car was only running 12.0's w/ a 1.65 foot. I can tell you they do need a "break in" period. Mine seemed to start hooking better after the 2-3rd time to the track. And as mentioned 17 is a good place to start. Whoops radials need more pressure, they aren't made to "wrinkle" they will "cup". Try 20-22lbs. And yeah Hemi + 4 speed + 4.30's =
[Re: Mr.Yuck]
#354516
06/22/09 06:56 PM
06/22/09 06:56 PM
Posts: 4,027 Dearborn Hts, MI
Sledge_57
Dearborn Hts, MI
I have the same tires and a slow car, but I started at 22psi and kept picking up every time I lowered the pressure until I got to 18psi which then hooked hard enough to snap an axle. So I'd say the 17-18psi range sounds like a good place to start too.
No tubes or screws in mine but like I said I'm slow .........
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
[Re: KatFysh]
#354518
06/23/09 12:15 AM
06/23/09 12:15 AM
Triple Threat
Renton Washington
My car will hook with them anywhere from 15-22+ The more air i have in them, the faster the car 60s.
[Re: Triple Threat]
#354519
06/23/09 07:43 AM
06/23/09 07:43 AM
an8sec70cuda
Mine still hooks with lower pressure, but it has kept getting quicker every time I raised the pressure. CHIP
[Re: an8sec70cuda]
#354520
06/23/09 08:26 AM
06/23/09 08:26 AM
Posts: 351 michigan
64ssmax
michigan
Rim width has alot to do with where your air pressure should be. Also your tire pressure gage may give you a different reading than someone elses meaning one gage may read 10 lbs and another gage may read 12 lbs. Like above start in the mid 20's and lower from there. You need to just look at the wear pattern on the tire to dial it in.
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end"
[Re: fourgearsavoy]
#354522
06/23/09 10:24 PM
06/23/09 10:24 PM
Posts: 892 USA
krw71ragtop
USA
I sure am glad this thread came up because I bought a set for my Savoy and I am almost done with the engine.I cant wait to start the heat cycles Gus
Same here Gus ! Just got mine last Friday. Hope to have my car done before summer is over. I had some of the same questions and will be watching this thread. Mine are Greg Weld wheels 15X8, P275/60/R15's
[Re: 9 Sec Phill]
#354524
06/24/09 08:35 AM
06/24/09 08:35 AM
Posts: 902 Mopar Lane,Mississippi
67HEMI
17-18 psi on mine with screws.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: Triple Threat]
#354525
06/24/09 08:40 AM
06/24/09 08:40 AM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
same here
