M/T ET Street tire question #354509
06/22/09 11:23 AM
06/22/09 11:23 AM
Davenport, IA
70shaker Offline OP
70shaker  Offline OP
Davenport, IA
Just mounted a set of 275-60 ET Streets on my Challenger and I am going to run it down the track soon. I do not have tubes. This is the first time on the track in 20 plus years. Do I need to screw these to the rims?
What is a good starting point for tire pressure? Also what is a good or safe range to run these tires?
Car is 70 Challenger. 472 hemi on pump gas, 4 speed, 4:30 gears.
Ex Hemi Racer
70 Challenger Hemi 4 speed clone
Re: M/T ET Street tire question [Re: 70shaker] #354510
06/22/09 11:26 AM
06/22/09 11:26 AM
an8sec70cuda Offline
I'd start with 17 psi and go UP from there. If it hooks hard it will most likely spin the rim inside the tire a little, but screws are not mandatory. If the track is good, I will run 19.5 to 20 psi in mine, although I'm running the bigger 295-65 radials. I have been almost as fast on the 275-60's though. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: M/T ET Street tire question [Re: 70shaker] #354511
06/22/09 11:27 AM
06/22/09 11:27 AM
Renton Washington
Triple Threat Offline
Renton Washington
Are these the Radial or Bias ply Version? If they're radial, you don't use tubes.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: M/T ET Street tire question [Re: Triple Threat] #354512
06/22/09 11:35 AM
06/22/09 11:35 AM
Davenport, IA
70shaker Offline OP
70shaker  Offline OP
Davenport, IA
They are radials
Ex Hemi Racer
Re: M/T ET Street tire question [Re: 70shaker] #354513
06/22/09 11:39 AM
06/22/09 11:39 AM
I run 15 lbs in mine,she seems to like it there best, i started at 20 and made my way down others at the track run the same pressure..
Re: M/T ET Street tire question [Re: 70shaker] #354514
06/22/09 12:08 PM
06/22/09 12:08 PM
The ET Street Radail may not be the best street strip tire for your car due to the 4 speed I don't know which one would be better, sorry. I do run the MT 315x60x15 on my car and have found that no two tire gauges are exactly the same, I use the same gauge now and run 18 to 22 lbs depending on the track I'm at Buy a good gauge and try different pressures to find out what your car wants
Re: M/T ET Street tire question [Re: 70shaker] #354515
06/22/09 12:26 PM
06/22/09 12:26 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I didn't screw mine. But then again the car was only running 12.0's w/ a 1.65 foot. I can tell you they do need a "break in" period. Mine seemed to start hooking better after the 2-3rd time to the track. And as mentioned 17 is a good place to start.
Whoops radials need more pressure, they aren't made to "wrinkle" they will "cup". Try 20-22lbs. And yeah Hemi + 4 speed + 4.30's =
Coming soon!!!!
Re: M/T ET Street tire question [Re: Mr.Yuck] #354516
06/22/09 06:56 PM
06/22/09 06:56 PM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
I have the same tires and a slow car, but I started at 22psi and kept picking up every time I lowered the pressure until I got to 18psi which then hooked hard enough to snap an axle. So I'd say the 17-18psi range sounds like a good place to start too.
No tubes or screws in mine but like I said I'm slow .........
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: M/T ET Street tire question [Re: Sledge_57] #354517
06/22/09 07:10 PM
06/22/09 07:10 PM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
I started with mine at 18 and went lower. Right now I am at 14 and I think it likes it there. But I am on a different track this year. 9secphill mentioned that I should try going back up and see how my 60's vary. Next time out I think I'll try 17 and see what happens. I bought my wheels used and they had screw holes in them. I still haven't installed the screws and I've made maybe 35 passes on them between last year and this past weekend. Not to mention the "street tatts" I leave.. Not sure about a 4spd though. Mark the tire to the wheels and see what happens. I agree, they need to be heat cycled when new.
When you decide to quit, THAT is the moment when you would've succeeded..
Re: M/T ET Street tire question [Re: KatFysh] #354518
06/23/09 12:15 AM
06/23/09 12:15 AM
Renton Washington
Renton Washington
My car will hook with them anywhere from 15-22+ The more air i have in them, the faster the car 60s.
-Dustin
Re: M/T ET Street tire question [Re: Triple Threat] #354519
06/23/09 07:43 AM
06/23/09 07:43 AM
Mine still hooks with lower pressure, but it has kept getting quicker every time I raised the pressure. CHIP
CHIP
Re: M/T ET Street tire question [Re: an8sec70cuda] #354520
06/23/09 08:26 AM
06/23/09 08:26 AM
michigan
64ssmax Offline
64ssmax  Offline
michigan
Rim width has alot to do with where your air pressure should be. Also your tire pressure gage may give you a different reading than someone elses meaning one gage may read 10 lbs and another gage may read 12 lbs. Like above start in the mid 20's and lower from there. You need to just look at the wear pattern on the tire to dial it in.
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end"
Re: M/T ET Street tire question [Re: 64ssmax] #354521
06/23/09 10:02 PM
06/23/09 10:02 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I sure am glad this thread came up because I bought a set for my Savoy and I am almost done with the engine.I cant wait to start the heat cycles
Gus
64 Plymouth Savoy
Dana 60
Re: M/T ET Street tire question [Re: fourgearsavoy] #354522
06/23/09 10:24 PM
06/23/09 10:24 PM
USA
K
krw71ragtop Offline
krw71ragtop  Offline
K
USA
Gus
Same here Gus ! Just got mine last Friday. Hope to have my car done before summer is over. I had some of the same questions and will be watching this thread. Mine are Greg Weld wheels 15X8, P275/60/R15's
Re: M/T ET Street tire question [Re: krw71ragtop] #354523
06/23/09 11:17 PM
06/23/09 11:17 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
The old cuda would 60' 1.36 with these tires. No 4 link or cal tracks just old 002,003 SS springs with no snubber. 18 psi and a three count on the burn out and pull to the line. Hooked every time and left many wall to wall tire drag cars at the tree...Phill
Re: M/T ET Street tire question [Re: 9 Sec Phill] #354524
06/24/09 08:35 AM
06/24/09 08:35 AM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
17-18 psi on mine with screws.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: M/T ET Street tire question [Re: Triple Threat] #354525
06/24/09 08:40 AM
06/24/09 08:40 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
same here
