We call it DAKSOTA #353649
06/21/09 06:14 PM
06/21/09 06:14 PM
MS
redex79 Offline OP
redex79  Offline OP
MS
I have been helping a fellow Mopar buddy with his 40 Desoto. After considering several options to the original frame front suspension we decided to implant a 97 Dakota frame. So far so good. Now I've never done a street rod before, been a Mopar man for many years so here's what it looks like so far. The first pic is the Ply 318 wit a 904 mocked up in the 97 Dak frame with the Desoto front cap on. Take a look
Truckin Weekend !
70 Dodge Dart Swinger
11 Ram 1500 Laramie 4x4
21 Dodge Durango GT
Re: We call it DAKSOTA [Re: redex79] #353650
06/21/09 06:17 PM
06/21/09 06:17 PM
MS
redex79 Offline OP
redex79  Offline OP
MS
Here's the Poly 318, 904 and radiator installed. Fired it up yesterday, so far so good. I plan on mocking the body up soon.
Truckin Weekend !
21 Dodge Durango GT
Re: We call it DAKSOTA [Re: redex79] #353651
06/21/09 06:19 PM
06/21/09 06:19 PM
MS
redex79 Offline OP
redex79  Offline OP
MS
Here's a end shot of the cap and Poly with trans.
Truckin Weekend !
21 Dodge Durango GT
Re: We call it DAKSOTA [Re: redex79] #353652
06/21/09 06:21 PM
06/21/09 06:21 PM
MS
redex79 Offline OP
redex79  Offline OP
MS
Here's another.
Truckin Weekend !
21 Dodge Durango GT
Re: We call it DAKSOTA [Re: redex79] #353653
06/21/09 06:28 PM
06/21/09 06:28 PM
MS
redex79 Offline OP
redex79  Offline OP
MS
This is the latest photo with the radiator lowered from the original mock up. Had to use the Dakota P/S pump. Originaly was going to use the older style P/S pump. Had clearance issues with the rack and pinion steering shaft.
Truckin Weekend !
21 Dodge Durango GT
Re: We call it DAKSOTA [Re: redex79] #353654
06/21/09 10:09 PM
06/21/09 10:09 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Looks good! Let us know how far back the motor ends up from the original Dakota location.
Did you see the frame drawings I posted?
Re: We call it DAKSOTA [Re: RodStRace] #353655
06/21/09 10:35 PM
06/21/09 10:35 PM
MS
redex79 Offline OP
redex79  Offline OP
MS
I saw some of them. Here's some shots of the frame mounts I fabricated. You can get an idea. I'll try and get some deminsions. The thing I had to consider on the 40 Desoto was the front cap mounting. I was trying to get the placement of the front wheel openings in relation to the Dakota frame without cutting the frame in half. Here's the pics.
Truckin Weekend !
21 Dodge Durango GT
Re: We call it DAKSOTA [Re: redex79] #353656
06/21/09 10:37 PM
06/21/09 10:37 PM
MS
redex79 Offline OP
redex79  Offline OP
MS
LH Side
Truckin Weekend !
21 Dodge Durango GT
Re: We call it DAKSOTA [Re: redex79] #353657
06/21/09 11:29 PM
06/21/09 11:29 PM
BRIGHTON ,TENNESSEE USA
MOPARWOODY Offline
MOPARWOODY  Offline
hey man that looks great,you have come a long way on that project keep it up
Re: We call it DAKSOTA [Re: RodStRace] #353658
06/22/09 10:46 AM
06/22/09 10:46 AM
MS
redex79 Offline OP
redex79  Offline OP
MS
10" (+-) from center of original mount to center of fabed mount. Or measured from #1 plug to center of ball joint- 4"
The mounts and brackets are from a small block 77 Dodge truck.
Truckin Weekend !
21 Dodge Durango GT
Re: We call it DAKSOTA [Re: redex79] #353659
06/22/09 12:35 PM
06/22/09 12:35 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
what did you use as far as belts/pullys? i know the newer p/s pump uses flat/serpentine and the old one uses a v-belt.
Re: We call it DAKSOTA [Re: 65rbdodge] #353660
06/22/09 01:45 PM
06/22/09 01:45 PM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
That is so cool! Thanks a ton for the pictures!
Excellent choice of engine, too!
Re: We call it DAKSOTA [Re: 65rbdodge] #353661
06/22/09 03:10 PM
06/22/09 03:10 PM
MS
redex79 Offline OP
redex79  Offline OP
MS
The crank and water pump was a small block set up from the donor truck as was the alt. I pulled the serp. pulley off the P/S pump and installed a pulley from an older P/s Pump. The shaft is larger on the Dak P/S pump so the hole on the older pulley had to be enlarged. Having some problem with that since I don't have a drill press I used my die grinder and a small flap wheel. Might be a bit too big. Here's some pics of the pulley set up.
Truckin Weekend !
21 Dodge Durango GT
Re: We call it DAKSOTA [Re: redex79] #353662
06/22/09 03:12 PM
06/22/09 03:12 PM
MS
redex79 Offline OP
redex79  Offline OP
MS
more pics
Truckin Weekend !
21 Dodge Durango GT
Re: We call it DAKSOTA [Re: redex79] #353663
06/22/09 03:12 PM
06/22/09 03:12 PM
MS
redex79 Offline OP
redex79  Offline OP
MS
nuther
Truckin Weekend !
21 Dodge Durango GT
Re: We call it DAKSOTA [Re: redex79] #353664
06/22/09 03:19 PM
06/22/09 03:19 PM
MS
redex79 Offline OP
redex79  Offline OP
MS
The Poly might be on its way out. I ran it this morning checking everything out and it began having excessive blow by. It was pushing oil out every hole it could find. I have another Poly 318 I can put in its place but I'm leaving that up to my buddy the owner.
Truckin Weekend !
21 Dodge Durango GT
Re: We call it DAKSOTA [Re: redex79] #353665
06/22/09 03:58 PM
06/22/09 03:58 PM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
Check the PCV valve...
2 Demons...no, not my kids!
Re: We call it DAKSOTA [Re: 4speeds4me] #353666
06/22/09 06:05 PM
06/22/09 06:05 PM
MS
redex79 Offline OP
redex79  Offline OP
MS
It's worse than that. It was working correctly. I feal like it's a broken or stuck piston ring. Engine is a 65 model and had a lot of sludge.
Truckin Weekend !
21 Dodge Durango GT
Re: We call it DAKSOTA [Re: redex79] #353667
06/23/09 08:02 AM
06/23/09 08:02 AM
MS
redex79 Offline OP
redex79  Offline OP
MS
Well It looks like a 68 LA 318 is going in in place of the old Poly. As soon as I get back from the F.A.S.T races in Martin, MI i'll start work on that task.
Truckin Weekend !
21 Dodge Durango GT
Re: We call it DAKSOTA [Re: redex79] #353668
06/23/09 10:45 AM
06/23/09 10:45 AM
Jackstandville Fl.
Captain Chaos Offline
Jackstandville Fl.
Thats awesome, theres a 50's Dodge truck that comes to the Garlits show in Ocala that has Dakota stuff throughout it. I believe its using second gen stuff though. The main benefit to that would be the ability to convert to 5 lug wheels.
Can't wait to see the body on it!
66 Plymouth Belvedere II The high school sweetheart 67 Plymouth Valiant the rusty project for sale 95 Dodge Dakota bracket race project
