We call it DAKSOTA
#353649
06/21/09 06:14 PM
06/21/09 06:14 PM
Posts: 1,417 MS
redex79
MS
I have been helping a fellow Mopar buddy with his 40 Desoto. After considering several options to the original frame front suspension we decided to implant a 97 Dakota frame. So far so good. Now I've never done a street rod before, been a Mopar man for many years so here's what it looks like so far. The first pic is the Ply 318 wit a 904 mocked up in the 97 Dak frame with the Desoto front cap on. Take a look
Truckin Weekend ! 70 Dodge Dart Swinger 11 Ram 1500 Laramie 4x4 21 Dodge Durango GT
Re: We call it DAKSOTA
[Re: redex79]
#353650
06/21/09 06:17 PM
06/21/09 06:17 PM
Posts: 1,417 MS
redex79
MS
Here's the Poly 318, 904 and radiator installed. Fired it up yesterday, so far so good. I plan on mocking the body up soon.
[Re: redex79]
#353651
06/21/09 06:19 PM
06/21/09 06:19 PM
Posts: 1,417 MS
redex79
MS
Here's a end shot of the cap and Poly with trans.
[Re: redex79]
#353652
06/21/09 06:21 PM
06/21/09 06:21 PM
Posts: 1,417 MS
redex79
MS
Here's another.
[Re: redex79]
#353653
06/21/09 06:28 PM
06/21/09 06:28 PM
Posts: 1,417 MS
redex79
MS
This is the latest photo with the radiator lowered from the original mock up. Had to use the Dakota P/S pump. Originaly was going to use the older style P/S pump. Had clearance issues with the rack and pinion steering shaft.
[Re: RodStRace]
#353655
06/21/09 10:35 PM
06/21/09 10:35 PM
Posts: 1,417 MS
redex79
MS
I saw some of them. Here's some shots of the frame mounts I fabricated. You can get an idea. I'll try and get some deminsions. The thing I had to consider on the 40 Desoto was the front cap mounting. I was trying to get the placement of the front wheel openings in relation to the Dakota frame without cutting the frame in half. Here's the pics.
[Re: RodStRace]
#353658
06/22/09 10:46 AM
06/22/09 10:46 AM
Posts: 1,417 MS
redex79
MS
Looks good! Let us know how far back the motor ends up from the original Dakota location. Did you see the frame drawings I posted?
10" (+-) from center of original mount to center of fabed mount. Or measured from #1 plug to center of ball joint- 4"
The mounts and brackets are from a small block 77 Dodge truck.
[Re: 4speeds4me]
#353666
06/22/09 06:05 PM
06/22/09 06:05 PM
Posts: 1,417 MS
redex79
MS
It's worse than that. It was working correctly. I feal like it's a broken or stuck piston ring. Engine is a 65 model and had a lot of sludge.
[Re: redex79]
#353667
06/23/09 08:02 AM
06/23/09 08:02 AM
Posts: 1,417 MS
redex79
MS
Well It looks like a 68 LA 318 is going in in place of the old Poly. As soon as I get back from the F.A.S.T races in Martin, MI i'll start work on that task.
[Re: redex79]
#353668
06/23/09 10:45 AM
06/23/09 10:45 AM
Posts: 56 Jackstandville Fl.
Captain Chaos
Jackstandville Fl.
Thats awesome, theres a 50's Dodge truck that comes to the Garlits show in Ocala that has Dakota stuff throughout it. I believe its using second gen stuff though. The main benefit to that would be the ability to convert to 5 lug wheels.
Can't wait to see the body on it!
66 Plymouth Belvedere II The high school sweetheart
67 Plymouth Valiant the rusty project for sale
95 Dodge Dakota bracket race project
