Hemi piston compression height question #352444
06/20/09 07:14 AM
06/20/09 07:14 AM
QLD Australia
Keith Black® Offline OP
QLD Australia
I am building a world products block and will use a 4.500 stroke crank with 7.100 rods, w/4.25 finished bore.. standard deck height 10.725.
I need to get custom pistons made (J/E). Does anyone know if the Piston compression height (calculated to be 1.375" puts the pin into the oil ring land ..?.. probems with this scenario...? ... balancing ..?
Any help, suggestions or comments appreciated!
Darren Beale
Keith Black Racing Engines®
Re: Hemi piston compression height question [Re: Keith Black®] #352445
06/20/09 10:30 AM
06/20/09 10:30 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
"Does anyone know if the Piston compression height (calculated to be 1.375" puts the pin into the oil ring land ..?"
All I can tell you for sure is, that my 4.50" stroke with 7.100 rods put the pin in the oil ring land and requires a support rail. This is not a problem.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Hemi piston compression height question [Re: Hemi Allstate] #352446
06/20/09 12:35 PM
06/20/09 12:35 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
4.5 stroke, 7.1 rod, you will need support rails.
Re: Hemi piston compression height question [Re: SSAAHemiFan] #352447
06/20/09 02:44 PM
06/20/09 02:44 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Look here is my 572 rod and piston. Yes the wrist pin is in the oil ring.
Re: Hemi piston compression height question [Re: Bob_Coomer] #352448
06/20/09 06:59 PM
06/20/09 06:59 PM
QLD Australia
QLD Australia
Thanks a million for your help!
Hoping to get a combo that balances up alright without cutting into rods/pistons/crank. Any thoughts appreciated. J/E Pistons (11:1 w/ 168cc Stage V Heads) + 7.100 parabolic beam Oliver Rods + billet crank (FHO)/or Ohio Crank (still undecided). street motor.
Darren Beale
Re: Hemi piston compression height question [Re: Keith Black®] #352449
06/20/09 11:08 PM
06/20/09 11:08 PM
Southington Ct.
turbobitt Online content
turbobitt  Online Content
Southington Ct.
I used a 7.0 K1 chevy rod and chevy pin with a 4.5 stroke and the pin clears the bottom ring land. Plenty of people have run with no issues with the support rail but this is another option.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Hemi piston compression height question [Re: turbobitt] #352450
06/21/09 12:43 AM
06/21/09 12:43 AM
Mt. Eden Ky.
Mt. Eden Ky.
Allan G.
Hmmmm.......FWIW I am using the K1 4.5 crank with Chevy pin size and K1 7.1 rods. My pistons are CP.
I did have to use support rails in my engine.
I guess the top ring placement could be moved up, but......
1996 Ram 1500 Sport
1968 road runner
Re: Hemi piston compression height question [Re: Hemi Allstate] #352451
06/21/09 05:37 PM
06/21/09 05:37 PM
Southington Ct.
Southington Ct.
Allan G.
I used 4.5 K1 crank but with Diamond pistons. Definetly no support rail with 7" rod. Pistons were spec'ed by Dram.
Allan G.
