Hemi piston compression height question
#352444
06/20/09 07:14 AM
06/20/09 07:14 AM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
I am building a world products block and will use a 4.500 stroke crank with 7.100 rods, w/4.25 finished bore.. standard deck height 10.725. I need to get custom pistons made (J/E). Does anyone know if the Piston compression height (calculated to be 1.375" puts the pin into the oil ring land ..?.. probems with this scenario...? ... balancing ..? Any help, suggestions or comments appreciated!
-------------------------------- Darren Beale Keith Black Racing Engines®
Re: Hemi piston compression height question
[Re: Keith Black®]
#352445
06/20/09 10:30 AM
06/20/09 10:30 AM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
"Does anyone know if the Piston compression height (calculated to be 1.375" puts the pin into the oil ring land ..?" All I can tell you for sure is, that my 4.50" stroke with 7.100 rods put the pin in the oil ring land and requires a support rail. This is not a problem. Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Bob_Coomer]
#352448
06/20/09 06:59 PM
06/20/09 06:59 PM
Keith Black®
QLD Australia
Thanks a million for your help! Hoping to get a combo that balances up alright without cutting into rods/pistons/crank. Any thoughts appreciated. J/E Pistons (11:1 w/ 168cc Stage V Heads) + 7.100 parabolic beam Oliver Rods + billet crank (FHO)/or Ohio Crank (still undecided). street motor.
[Re: Keith Black®]
#352449
06/20/09 11:08 PM
06/20/09 11:08 PM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
I used a 7.0 K1 chevy rod and chevy pin with a 4.5 stroke and the pin clears the bottom ring land. Plenty of people have run with no issues with the support rail but this is another option. Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
