electronic to points conversion #351651
06/19/09 09:45 AM
06/19/09 09:45 AM
Mansfield, PA
thawarden Offline OP
Mansfield, PA
Hey guys, just curious what is involved in converting my electronic ignition to a points ignition.
I have a new points distributor but I have no idea what wires if any I need to use from the 5 pin connector that goes to the ecu.
Thanks in advance.
Re: electronic to points conversion [Re: thawarden] #351652
06/19/09 09:54 AM
06/19/09 09:54 AM
scratchnfotraction Offline
I do this alot myself
my 85 truck...has the ecu and elect dizzy
I get a points dizzy from auto zone
install a pertronix points conversion in the oints dizzy
drop it in the engine,leave all the wire harness and ecu in place
drop the neg wire on coil for elect dizzy
use the keyed hot wire from haness with red wire from conversion on + side of coil
add black wire from conversion to neg side of coil
done,been doin it that way for yrs and no probs
if you just use points...
drop in the dizzy,drop elect dizzy wire from neg side of coil and hook up black wire from points to neg side of coil...done
I did change points every 3-6 mounths though
cant really tell it swaped over unless you know what wires to look for
scratchin
Re: electronic to points conversion [Re: scratchnfotraction] #351653
06/19/09 11:22 AM
06/19/09 11:22 AM
If you are using a Mopar ECU all you need to do is yank the connector out of the ECU, and hook the (only) wire from the dist to the neg. side of the coil.
Re: electronic to points conversion #351654
06/19/09 05:59 PM
06/19/09 05:59 PM
I have never unplugged the ecu when just hooking the ground wire from the points to the neg side of coil
but either way works I guess
scratchin
Re: electronic to points conversion [Re: scratchnfotraction] #351655
06/19/09 07:05 PM
06/19/09 07:05 PM
scratchin
Just more for safety I guess. If the ECU quit--the reason for the conversion, there's some chance of a short there
Re: electronic to points conversion #351656
06/19/09 07:18 PM
06/19/09 07:18 PM
ok I can with that!
never even thought about it that way either
most times I dont have a failure,its just a thing I do to one I get first thing
thanks for that tip
scratchin
Re: electronic to points conversion [Re: scratchnfotraction] #351657
06/19/09 07:21 PM
06/19/09 07:21 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
electronic to points is absolutely rediculas...
I am truckless..
Re: electronic to points conversion [Re: 340SHORTY] #351658
06/19/09 07:34 PM
06/19/09 07:34 PM
say that in the dark..on side of the road...in the boonedocks...while waiting for the wify to get it out of the shed and bring it way out there to you... after walking her out there over the phone and finding it on the shelf...cause she duzz the house not the car work and parts changing
then change it in the dark on the now cooled down engine
and I use the pertronix conversion most the time anyways..that swaps it back to electronic and more fire at the plug with the 40,000 volt flame thrower coil that goes with it than any stock smog crap leanburn ecu crap..IMO
the points dizzy even has a slightly better advance curve built in to it than the stock dizzy, so it more tunable with a non emmision carb and headers
runwhatyabrung..I do!
scratchin
Re: electronic to points conversion [Re: thawarden] #351659
06/21/09 08:21 AM
06/21/09 08:21 AM
Mass
dgc333 Offline
dgc333  Offline
Mass
Thanks in advance.
You don't need any of the wires from the 5-pin connector. The wiring from tha ballast resistor to the coil stays the same and the wire from the points distributor connects to the negative side of the coil in place of the wire from the ecu. You don't even need to disconnect the ecu.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
