Hey guys, just curious what is involved in converting my electronic ignition to a points ignition.
I have a new points distributor but I have no idea what wires if any I need to use from the 5 pin connector that goes to the ecu.
Thanks in advance.
You don't need any of the wires from the 5-pin connector. The wiring from tha ballast resistor to the coil stays the same and the wire from the points distributor connects to the negative side of the coil in place of the wire from the ecu. You don't even need to disconnect the ecu.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
