C-body ball joint identification #349967
06/17/09 12:47 PM
06/17/09 12:47 PM
Charlotte, NC
446acuda Offline OP
446acuda  Offline OP
Charlotte, NC
I bought this new lower ball joint at a swap meet a few years ago without a box. I think it is a '65-73 C-body ball joint. Has 5/8" threads and 65 near the grease fitting and 24-4001-026 on the steering arm. Here is picture of it with a typical B/E/late A ball joint below. What is the difference between a '65-73 Imperial ball joint and a '65-73 C-body ball joint?
Re: C-body ball joint identification [Re: 446acuda] #349968
06/17/09 01:07 PM
06/17/09 01:07 PM
Rancho Cordova, California (Sa...
hemi71x Online content
hemi71x  Online Content
I took a front end apart recently on a 69 Imperial that had the old BUDD disc brake system on it.
The lower ball joint is pressed into the lower control arm on a car like that.
But i'm not sure if early 70's Imperials would have a bolt on ball joint to the spindle like the big one that you pictured.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: C-body ball joint identification [Re: hemi71x] #349969
06/17/09 01:18 PM
06/17/09 01:18 PM
Charlotte, NC
446acuda Offline OP
446acuda  Offline OP
Charlotte, NC
Thanks. As usual, there in no good info on the net about this kind of stuff.
Re: C-body ball joint identification [Re: 446acuda] #349970
06/18/09 05:03 PM
06/18/09 05:03 PM
Great White North
Furyman Offline
Furyman  Offline
Great White North
thats a c body 65-73 lower ball joint excluding 65-8 budd disc
"Long Live Mopars"
Re: C-body ball joint identification [Re: Furyman] #349971
06/18/09 05:28 PM
06/18/09 05:28 PM
Charlotte, NC
446acuda Offline OP
446acuda  Offline OP
Charlotte, NC
Thanks!!
