Re: C-body ball joint identification
[Re: 446acuda]
#349968
06/17/09 01:07 PM
06/17/09 01:07 PM
Posts: 5,360 Rancho Cordova, California (Sa...
hemi71x
I took a front end apart recently on a 69 Imperial that had the old BUDD disc brake system on it. The lower ball joint is pressed into the lower control arm on a car like that. But i'm not sure if early 70's Imperials would have a bolt on ball joint to the spindle like the big one that you pictured.
RF-4C Phantom 69-370 Zweibrucken, Germany
