None of the Keisler installs that I've done, have I used the BENCH 70 B body shifter,...stock or Keislers repro,.....the Keisler 68-70 B TKO application will move the shifter tower location approx, 3-4 inches right of stock shifter centerline location,....forward relocation is generally no more than 1 inch, from stock centerline,......regardless of shifter chosen, if it hits anything,....fabricate a offset, or relocation bracket to tailor the shifter to your needs,....there should be a relocation bracket supplied with your Keisler kit,......
