In-expensive compression gauge, yes/no? #347014
06/14/09 09:14 PM
06/14/09 09:14 PM
eastern, pa.
cudabitten Offline OP
eastern, pa.
Hi,
I going to need a compression gauge next to check on the condition of my engine before I go any further with my restore. Any suggestions for an in-expensive gauge.
Thanks,
Chris.
Re: In-expensive compression gauge, yes/no? [Re: cudabitten] #347015
06/14/09 11:19 PM
06/14/09 11:19 PM
Andrewh Offline
Andrewh  Offline
why not rent on?
Autozone, oreily both do the rent a tool thing.
Re: In-expensive compression gauge, yes/no? [Re: cudabitten] #347016
06/15/09 12:59 AM
06/15/09 12:59 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I would think any local discount parts store would have a working cheapy for you to buy. The ones you have to hold in the hole are pretty much useless though. Better to be a thread in for sure.
Keep in mind, the number you read isn't as important at the variance between the cylinders
Re: In-expensive compression gauge, yes/no? [Re: Andrewh] #347017
06/15/09 12:59 AM
06/15/09 12:59 AM
Minnesota
duster340 Offline
duster340  Offline
Minnesota
so does advance auto parts, you pay for the tool in full, then when you bring it back you get refunded.
05 Dodge ram 1500 daytona 03 Dodge Durango 98 Chrysler Sebring 71 Dodge Super Bee 70 Plymouth Duster
Re: In-expensive compression gauge, yes/no? [Re: duster340] #347018
06/15/09 10:59 AM
06/15/09 10:59 AM
Flint, MI
Gusteve Offline
I Love the Unicorn Song!!
Gusteve  Offline
Flint, MI
Seems to me its the kind of tool you'd want to own, rather than rent. Its not like you are only going to use it one time and never need one again.
And yes, get the threaded kind, and one that "remembers" the compression reading until you hit the button to release the pressure. As said above, the one you hold into the plug holes are pretty useless.
Re: In-expensive compression gauge, yes/no? [Re: Gusteve] #347019
06/15/09 11:15 AM
06/15/09 11:15 AM
Central Ky, area
CHRYCOFAN Offline
CHRYCOFAN  Offline
Central Ky, area
Mine is an old Sears unit that screw in & has the end fitting for both size plugs. The hose also has a standard disconnect in the middle so that my air hose would plug on & you can pump cylinders. Also nice to just screw the hose in & listen for compression when checking for TDC.
Sears might still have something like that?
Mine's over 20 years old now.
Edit.....here's what sears has now, the Actron is what my old one is like.
http://www.sears.com/shc/s/search_10153_12605?keyword=compression+tester&x=0&y=0
Butch
Re: In-expensive compression gauge, yes/no? [Re: CHRYCOFAN] #347020
06/15/09 11:32 AM
06/15/09 11:32 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
in-expensive? the threaded ones that remember the pressure reading until you re-set them, are only like $15-20 at the local parts store...how cheap are you looking to get?
**Photobucket sucks**
Re: In-expensive compression gauge, yes/no? [Re: CHRYCOFAN] #347021
06/15/09 07:54 PM
06/15/09 07:54 PM
eastern, pa.
eastern, pa.
Hey CHRYCOFAN,
Thanks for the effort. That looks fine to me. 30 bucks is nothing compared to what I've been spending on this project. What's the purpose of putting air in the disconnected hose?
Re: In-expensive compression gauge, yes/no? [Re: cudabitten] #347022
06/15/09 08:35 PM
06/15/09 08:35 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Hey CHRYCOFAN,
If you want to do an audible leakdown, you can carefully bring the engine up to TDC on that cylinder, and pressureize it. If it's a few degrees off one way or the other, it will move!!!
If you hear air out the carb, the intake valve is leaking. If you hear air out the exhaust, the exhaust valve is leaking. If you hear air in the radiator, uh-oh. If you hear a lot of air (some is normal) coming out of the breather, the rings are leaking.
You can also do the valve spring removing trick if you dare. Remove the rocker arms, use a socket to pop the keepers (they get jammed on), then pressurize the cylinder and use a tool to compress the spring and retainer and remove the keepers. This can also be done with a section of rope, inserting with the piston down, then rotating the engine so the piston holds the rope up against the valve.
Using air is cleaner and easier, but if a valve drops, you have to pull the head.
Re: In-expensive compression gauge, yes/no? [Re: RodStRace] #347023
06/16/09 11:47 AM
06/16/09 11:47 AM
Central Ky, area
CHRYCOFAN Offline
CHRYCOFAN  Offline
Central Ky, area
I just looked at Sears but like he said check the local parts houses too, might find something just as good & cheaper.
All of what ROD said plus it's nice to thread the hose in when timing an engine for the first time to make sure you're on the compression stroke of #1, beats sticking your finger in the plug hole.
Butch
