Mech. roller cam in small block questions #346924
06/14/09 07:02 PM
06/14/09 07:02 PM
Stoney Creek, Ontario, Canada
76Beeper Offline OP
76Beeper  Offline OP
Guys: I'm thinking about running a Comp cams solid roller cam in my 360 motor. It's the Magnum 288R cam. My question is...what has to be done to the block to run a roller cam in a non-roller motor? (my block was cast in 76)
Re: Mech. roller cam in small block questions [Re: 76Beeper] #346925
06/15/09 07:32 AM
06/15/09 07:32 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Contact member OU812, he sells some that are supposed to be drop in. Most others require grinding to clear the connector bars.
Re: Mech. roller cam in small block questions [Re: 76Beeper] #346926
06/15/09 07:46 AM
06/15/09 07:46 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Talk to board member OU812 (Brian at IMM) IIRC he has some comp drop in lifters that really don't require anything to run a cam with up to ~.450" lobe lift
2017 Grand Cherokee Overland
Re: Mech. roller cam in small block questions [Re: justinp61] #346927
06/15/09 07:49 AM
06/15/09 07:49 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Some method of oil control should be done. I will not run a solid roller without running lifter bore buishings. You could also have the block tubed and get some of the protection from pressure issues. Clearancing the block for the lifters on most production blocks in not a big deal. I think Brian's dont need any work at all but I'm not sure. You'll also need the right valve springs and the right oil pump drive.
Re: Mech. roller cam in small block questions [Re: moper] #346928
06/15/09 08:17 AM
06/15/09 08:17 AM
Az
Crizila Offline
Crizila  Offline
Az
Check out August "Mopar Muscle". They have a pretty good article on the subject.
Fastest 300
Re: Mech. roller cam in small block questions [Re: Crizila] #346929
06/15/09 08:54 PM
06/15/09 08:54 PM
76Beeper Offline OP
76Beeper  Offline OP
Thanks for the replies guys.
The cam in question is a .550 lift.
I'll have to look out for the August issue.
I don't think it's out in my neck of the woods yet(southern Ontario, Canada)
I was wondering if the block did need some mod's done to it.
Re: Mech. roller cam in small block questions [Re: 76Beeper] #346930
06/15/09 10:07 PM
06/15/09 10:07 PM
scratchnfotraction Offline
the ones ou812 has...has a longer skirt to fix the oiling problem of the lifter uncovering the oil gally and loosing pressure with high lift cams IIRC
they have pressure oiling to the roller needle bearings also IIRC
and the link bar is to the cam side and not to the block side IIRC
maybe he will chime in and give a skoolin on them
on a non roller block...IIRC
the block will have to be clearaced in line with the lifter for the link bars to clear the block on other roller type lifters and should be bushed with high lifts so the oil passage is not uncoved
IIRC
lot easier and cheapr to start with a roller block IMO
unless ya just gotta keep that engine block for some reason
Re: Mech. roller cam in small block questions [Re: scratchnfotraction] #346931
06/16/09 10:31 AM
06/16/09 10:31 AM
SoCal
Brian Hafliger Offline
SoCal
Yes these just drop right in. Sometimes I have the base circle reduced to help lower the lifter in the bore some if the block has issues.
Brian
Re: Mech. roller cam in small block questions [Re: Brian Hafliger] #346932
06/16/09 12:16 PM
06/16/09 12:16 PM
76Beeper Offline OP
76Beeper  Offline OP
Thanks for the info Brian.
I did finally pick-up the Aug. edition of Mopar Muscle and in that article it says to have the oiling passages to the lifters restricted.
If I use your lifters Brian, will I still have to modify the block?
Re: Mech. roller cam in small block questions [Re: 76Beeper] #346933
06/16/09 02:40 PM
06/16/09 02:40 PM
SoCal
SoCal
If it's a stock block, no mods are neccessary. And these pushrod oil if you wanted to use that function.
Brian
Brian Hafliger
