Valve clearances- Hot or Cold #344562
06/12/09 07:22 AM
06/12/09 07:22 AM
Adelaide, SOUTH Australia
REDNICK Offline OP
REDNICK  Offline OP
Hi,
Whats the concensus?
Comp cams solid in a big block stroker engine.
Cam card gives clearances, but does this mean "hot" or "cold" ?
Nick
Re: Valve clearances- Hot or Cold [Re: REDNICK] #344563
06/12/09 07:29 AM
06/12/09 07:29 AM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Hot.
Re: Valve clearances- Hot or Cold [Re: earlybee] #344564
06/12/09 07:58 AM
06/12/09 07:58 AM
Az
Crizila Offline
Crizila  Offline
Az
Hot.
Fastest 300
Re: Valve clearances- Hot or Cold [Re: Crizila] #344565
06/12/09 09:28 AM
06/12/09 09:28 AM
REDNICK Offline OP
REDNICK  Offline OP
Roger.....
Thanks all
Re: Valve clearances- Hot or Cold [Re: REDNICK] #344566
06/12/09 10:31 AM
06/12/09 10:31 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The clearance #s they give are hot, but what I've always done is intially set them hot then wnen the engine cools down go back & measure them again... That now becomes my new "cold" valve setting... When trying to set the valves hot the engine is cooling the whole time your adjusting so the setting from one valve to the next varies & you might/probably should start the engine halfway through the process & warm it back up... It's easier to work on a nice thermally stable engine...The fact it won't burn the crap outta you doesn't hurt either..
BTW Nice 68!!
Re: Valve clearances- Hot or Cold [Re: REDNICK] #344567
06/12/09 11:20 AM
06/12/09 11:20 AM
Virginia
JimG Offline
JimG  Offline
Virginia
How long after shutting down a fully warmed engine does it cool enough to affect the valve settings in a negative way?
I've alwyas wondered.
Re: Valve clearances- Hot or Cold [Re: JimG] #344568
06/12/09 01:50 PM
06/12/09 01:50 PM
Detroit,MI
BADDART Offline
BADDART  Offline
Detroit,MI
I would just wait over nite,because a cold valve lash would be just that-dead cold. Chris
