1952 B3 pickup parts interchange? #344313
06/11/09 08:08 PM
06/11/09 08:08 PM
Lockport, New York, USA
ramified Offline OP
ramified  Offline OP
Having a hard time finding a fuel tank and brake componets (wheel cylinders, master, brakes, etc) for a 1953 B3 1/2 ton pickup. Does anyone know where to look or like a parts interchange off of another vehicle???
Re: 1952 B3 pickup parts interchange? [Re: ramified] #344314
06/11/09 10:30 PM
06/11/09 10:30 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Autozone.com has brake parts. Just looked
Re: 1952 B3 pickup parts interchange? [Re: ramified] #344315
06/11/09 11:08 PM
06/11/09 11:08 PM
CA - Lord help us!
GTXperience Offline
GTXperience  Offline
CA - Lord help us!
Ramified, I got a lot of my parts for my '51 from Roberts Motor Parts (in MA): http://www.robertsmotorparts.com/index.html
Here's the link to some of the brake parts: http://www.robertsmotorparts.com/truck_parts.asp?Action=search&c=Trucks+%2D+Brake+Parts
I have also used Andy Bernbaum Auto Parts Inc (also in MA): http://www.oldmoparts.com/
Here's the link to the brake parts: http://www.oldmoparts.com/g.htm
I hope this helps.
Re: 1952 B3 pickup parts interchange? [Re: ramified] #344316
06/11/09 11:09 PM
06/11/09 11:09 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Good luck finding an original fuel tank that is not rotted out. I just modified my first one and put a tank from a mid 70s Cordoba behind the rear axle.
www.robertsmotorparts.com has a lot of stuff for that era truck. I've gotten weatherstripping and other things from them. They know these trucks.
My current 50 is on an 80 Dodge short box 4x4 frame. It has a 360, 727, 9 1/4 rear and a D44 front with 3:55 gears. Gene
Re: 1952 B3 pickup parts interchange? [Re: poorboy] #344317
06/11/09 11:57 PM
06/11/09 11:57 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Taking good measurements and checking your local salvage yard is about the best bet.
If you really can't find anything, these guys can make one, but it's expensive. The one for my 47 sedan was priced at $800! I had the old one cleaned out at the local radiator shop.
http://www.rockvalleyantiqueautoparts.com/products.htm
I don't know how much carries over, but there is an active Power wagon site here.
http://www.dodgepowerwagon.com/main/parts.htm
Re: 1952 B3 pickup parts interchange? [Re: RodStRace] #344318
06/15/09 01:20 AM
06/15/09 01:20 AM
Rosedale B.C Canada.. Eh
Fargo Freek Offline
super gas
Fargo Freek  Offline
super gas
I have a refabercated tank that bolts into the stock mount looks like stock one but made out of thicker steal . will send pics when I get it out if your interested
I was the Black Warlock but now Iam the Fargo Freek 1950 plymouth fast back (custom) 1951 Fargo spring special 1996 Dodge 1500 Pu 2008 Magnum AWD The way I see it is If It doesn,t say MOPAR then what else is there. E Mail me @ nascar2000@telus.net
Re: 1952 B3 pickup parts interchange? [Re: Fargo Freek] #344319
06/15/09 10:38 PM
06/15/09 10:38 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Most qualified welding shops can build a tank for you, but they won't have the pretty curved corners. You just need a good guage/fuel pickup fitting to put into the tank. Gene
