are kickdown linkages engine specific? #343609
06/10/09 09:10 PM
06/10/09 09:10 PM
East Liverpool, OH
b body dreams Offline OP
East Liverpool, OH
I picked up a kickdown linkage for my 68 sport satellitte yesterday from a friend. Linkage came off a 400 with a 727. I installed it tonight on my car and test drove and it will only hit drive at about if you get it up to about 50 mph. And as soon as you let off the gas the trans downshifts back into second. I looked at the adjustment and it looks to me like the kickdown rod is to short on the transmission end. I still have alot of travel on the kickdown lever on the trans with the throttle wide open on the carb.
Re: are kickdown linkages engine specific? [Re: b body dreams] #343610
06/10/09 09:13 PM
06/10/09 09:13 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Not only are they engine specific, but bodystyle specific, too.
Re: are kickdown linkages engine specific? [Re: b body dreams] #343611
06/10/09 09:17 PM
06/10/09 09:17 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Totally different - They went one piece kickdown around '71. With the kick-down lever on the trans pulled all the way towards the front of the car the slotted lever (pulled all the way forward) should just be touching the carb throttle stud at idle.
Re: are kickdown linkages engine specific? [Re: FJ5_Fish] #343612
06/10/09 09:22 PM
06/10/09 09:22 PM
East Liverpool, OH
East Liverpool, OH
I know the one piece kickdown isnt right for my car but was trying to come up with something that will allow me to drive the car until I can aquire the correct one. The car and myself are supposed to be in my best friends wedding the 27th of this month.....Time and money are both running short....lol
Re: are kickdown linkages engine specific? [Re: FJ5_Fish] #343613
06/10/09 09:33 PM
06/10/09 09:33 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
That is what that small spring is for. To hold the rear of teh KD slot forward on the throtle pins for constant progress ive throttle pressure. Number 13 in the illustration.
Re: are kickdown linkages engine specific? [Re: b body dreams] #343614
06/10/09 09:43 PM
06/10/09 09:43 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
See if it will adjust the way I described - If it does it might work ok.
Re: are kickdown linkages engine specific? [Re: FJ5_Fish] #343615
06/10/09 10:21 PM
06/10/09 10:21 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I'm kinda surprised it fit an earlier car.
Re: are kickdown linkages engine specific? [Re: SomeCarGuy] #343616
06/10/09 10:23 PM
06/10/09 10:23 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Me three
Re: are kickdown linkages engine specific? [Re: FJ5_Fish] #343617
06/10/09 10:29 PM
06/10/09 10:29 PM
Can you fabricate it so the slotted rod starts moving when the throttle does and the lever at the trans is pretty much all the way back when someone is flooring the gas pedal.
Re: are kickdown linkages engine specific? [Re: RapidRobert] #343618
06/11/09 01:48 PM
06/11/09 01:48 PM
Wilmington, NC
donbarnes Offline
Not THAT Don Barnes!!
donbarnes  Offline
Wilmington, NC
This isn't what you asked, but the cable kit from Lokar is the best route, put mine on 3 years ago and haven't touched it since, well worth the money
Re: are kickdown linkages engine specific? [Re: donbarnes] #343619
06/11/09 05:28 PM
06/11/09 05:28 PM
East Liverpool, OH
East Liverpool, OH
I have looked at them on summits website but was really just trying to come up with something so that I can drive it without hurting the tranny till I can get a proper kickdown.....lokar or factory.....
Re: are kickdown linkages engine specific? [Re: b body dreams] #343620
06/11/09 06:39 PM
06/11/09 06:39 PM
Someone had posted in that case to wire it halfway back & leave it there for now but I would check with Kunkel to confirm
