My bellhousing runout numbers...what dowels do I need? #333032
05/30/09 12:00 AM
05/30/09 12:00 AM
Wichita,KS
Blakcharger440 Offline OP
Wichita,KS
The runout numbers on my Lakewood bellhousing are as follows.
Straight up and down I got .007
Left and Right I got .0135
What RobbMC dowels do I need in order to correct the alignment?
Re: My bellhousing runout numbers...what dowels do I need? [Re: Blakcharger440] #333033
05/30/09 12:29 AM
05/30/09 12:29 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I'm assuming all your "numbers" are both positive or both negitive of Zero,if so.... You'll need to buy a few sets, depending on what the manufacturer offers......for what dems you supplied .002 thru .010 offset, if your looking to get within .001-.0015 runout,.....it's a "trying" procedure, but well worth the benefits,.....when you tighten down the bell, try to replicate your torque pattern, as you find out, varying your tightning pattern, varies the runout!....make sure all the bolts are present in the bell, as you offset for dial in measurements
Re: My bellhousing runout numbers...what dowels do I need? [Re: DAYCLONA] #333034
05/30/09 01:44 AM
05/30/09 01:44 AM
Spokane,WA
Genuinejed Offline
Genuinejed  Offline
Spokane,WA
Not to hijack, but...something seems funny with your numbers. When I first checked mine I set the indicator to zero at 12 o'clock and it read .007 at 3 o'clock and 9 o'clock. It read .036 at 6 o'clock. I assumed the register was low on the engine and installed Lakewood .014 offset dowels with the offset straight up. This helped, but the measurement was still off .020 in the same direction. FSM sez use an offset dowel with half of the needed correction. I too am wondering how you are supposed to select the correct dowel.
1968 Plymouth road runner 1968 Dodge Coronet 500 64 D200 Good, Fast, Cheap. Pick Two.
Re: My bellhousing runout numbers...what dowels do I need? [Re: Blakcharger440] #333035
05/30/09 09:12 AM
05/30/09 09:12 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
A dowel around .009 installed at a slight upward (or downward) angle would probably solve your problem nicely.
Re: My bellhousing runout numbers...what dowels do I need? [Re: Blakcharger440] #333036
05/30/09 10:18 AM
05/30/09 10:18 AM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
If they are all positive numbers, then your total indicated runout is .0065. Max allowed runout is .008 so your is good to go without offset dowels although you may be able to tweek it to nearly perfect by using one standard dowel and one .007 dowel.
Re: My bellhousing runout numbers...what dowels do I need? [Re: 446acuda] #333037
05/30/09 12:20 PM
05/30/09 12:20 PM
Wichita,KS
Wichita,KS
What do you guys mean by "positive" numbers? When I measured at the 12:00 and 6:00 positions it read .007 and then I backed it up back to 12:00 just to make sure it went back to zero and it did...I did the same with the 3:00 and 9:00 positions which were .0135.
Is there something I am doing wrong here?
And I thought acceptable runout was supposed to be .005 At least that is what it says on the RobbMC website.
Re: My bellhousing runout numbers...what dowels do I need? [Re: Blakcharger440] #333038
05/31/09 12:08 PM
05/31/09 12:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
which way did it move postive or negative , meaning did the indicator move from 0 to 7 or from 0 to 93 ? same for the left and right ? you need to go .0035 in onedirecting and .0065 in the other so the dowel with the least offset should fix you right up
Re: My bellhousing runout numbers...what dowels do I need? [Re: JohnRR] #333039
05/31/09 01:05 PM
05/31/09 01:05 PM
Wichita,KS
Wichita,KS
I am not sure I understand. On my dial indicator the number to left of zero is 5 and the number to right of zero is 5. Both left and right progess to the total number of 20 at the bottom of the gauge.
Re: My bellhousing runout numbers...what dowels do I need? [Re: Blakcharger440] #333040
05/31/09 01:19 PM
05/31/09 01:19 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I always call right of zero positive and left of zero negative.
Re: My bellhousing runout numbers...what dowels do I need? [Re: Blakcharger440] #333041
05/31/09 01:25 PM
05/31/09 01:25 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Rotate the crank until the reading is at the lowest value (plunger extended). Mark this point on the bell and zero the indicator. Then roll the crank until the reading is at its maximum. Record the reading and mark the bell at that point. The off center value is half the indicator reading. If you draw a straight line through the two marks you made on the bell, the bell has to be shifted along the direction of the line, half the dial indicator reading, towards the second mark. BTW, the two marks should be directly opposite each other.
Re: My bellhousing runout numbers...what dowels do I need? [Re: Blakcharger440] #333042
05/31/09 07:14 PM
05/31/09 07:14 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
you posted a picture of this dial indicator in your other thread , how do i zero out my dial bore guage ...
Re: My bellhousing runout numbers...what dowels do I need? [Re: 6PakBee] #333043
05/31/09 07:18 PM
05/31/09 07:18 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
So at which point did you actually zero the indicator ???
You should be spinning the motor over and watching the indicator the whole time (a 2 person job). Pick the highest or lowest point (the point at which the indicator changes direction) and zero the indicator at that point. This becomes your starting position - now you want to take readings every 45 degrees to determine where the bellhousing is out the most. Once you determine that point and the amount its out you want a dowel with an offset as close to HALF that amount as possible and when you install it you want to be sure its oriented in that direction. This way regardless of what you've done the worst case scenario is that you'll have installed it 180 degrees out.
Now here's something I experienced ...
the bellhousing hole is not precision machined - sometimes even laser or flamecut. I use the adapter ring to check the runout as it is a machined piece. Hold it in place with some magnets.
Re: My bellhousing runout numbers...what dowels do I need? [Re: JohnRR] #333044
05/31/09 10:19 PM
05/31/09 10:19 PM
Wichita,KS
Wichita,KS
Hey John, I ended up using a different dial indicator that I borrowed from a friend who used to be a machinist. The dial indicator that I purchased from Harbor Freight in the pic was too big for the hole that I had a hard time adjusting it.
Re: My bellhousing runout numbers...what dowels do I need? [Re: Blakcharger440] #333045
05/31/09 10:34 PM
05/31/09 10:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Ok , I know what type you have , the needle will swing left and right of zero , you need to pay attention to that .
Re: My bellhousing runout numbers...what dowels do I need? [Re: JohnRR] #333046
05/31/09 10:36 PM
05/31/09 10:36 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
They all swing left and right once they're preloaded !!!
Re: My bellhousing runout numbers...what dowels do I need? [Re: Stanton] #333047
05/31/09 10:41 PM
05/31/09 10:41 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
OH really ??? thanks for the correction.
Re: My bellhousing runout numbers...what dowels do I need? [Re: JohnRR] #333048
06/05/09 08:22 PM
06/05/09 08:22 PM
Wichita,KS
Wichita,KS
I just wanted to get some input on the runout numbers that I got last night.
-.020 at the 2:00 position
.008 at the 8:00 position
What does that mean? At this point do I use the .007 dowel or the .014 dowel? Or do I just leave the stock ones in?
I had pulled the dial indicator assembly off last night and today I reinstalled it and got totally different numbers!
At this point I am planning on just keeping the stock dowels in and hoping for the best as I dont see a way to come up with some reliable numbers.
Re: My bellhousing runout numbers...what dowels do I need? [Re: Blakcharger440] #333049
06/05/09 08:30 PM
06/05/09 08:30 PM
Raleigh, NC
Y
Youngblood Offline
Youngblood  Offline
Y
Raleigh, NC
If you get -.020 and .008, your TIR (total indicator reading) is .028, and you need .014 offset dowels. You place them both in the same direction,in such a way to move the bell .014, which is half of your current TIR.
You don't want to run at .028, you will have problems.
Re: My bellhousing runout numbers...what dowels do I need? [Re: Blakcharger440] #333050
06/06/09 05:34 AM
06/06/09 05:34 AM
Martinez, California
Challenged Offline
Challenged  Offline
Just wanted to chime in. I have only done this once so I am no expert and I am curious if the method I used is correct. I used the method Keisler explains in their installation instructions as I am installing one of their TKO600 kits. Using their method you take 4 readings; 12:00, 03:00, 06:00 and 09:00. I zero'd my dial indicator at 12:00 so that reading is "0", 03:00 was -0.010, 06:00 was +0.002 and 09:00 was +0.012. Their method says to add the opposite readings then divide by 2 = runout in that direction. 12:00 + 06:00, 0 + 0.002 = 0.002 divided by 2 = 0.001 top/bottom runout; 09:00 + 03:00, 0.012 + -0.010 = 0.002 divided by 2 =0.001 left/right runout. If their method is correct using your numbers 02:00, -0.020 and 08:00, 0.008; -0.020 + 0.008 = -0.012 divded by 2 = a runout of 0.006, ignore the negative value. According to Keisler if your runout is more than 0.005 you will need to correct it.
Re: My bellhousing runout numbers...what dowels do I need? [Re: Challenged] #333051
06/06/09 09:49 AM
06/06/09 09:49 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
The Keisler method is one reason I hate overly complicated instructions for no real benefit. That method if followed to the letter depends on starting out with the dial indicator at '0'. If Blakcharger440 could do that (which apparently he can't), his numbers would be either '0' and '28' or '0' and '-28' depending on which point the dial was zeroed on. Youngblood and others are correct, the secret is Total Indicator Reading (TIR) which is double the offset. Based on Blak's last numbers, 0.014" would be the applicable correction.
