Re: 383 ID please [Re: JohnRR] #330438
06/01/09 12:53 AM
06/01/09 12:53 AM
St. John's Newfoundland
440newport Offline
440newport  Offline
No not an urban legend, C bodies up to 68 used the same mount as the A body, C bodies used the mount before it was also used on A bodies. I have a 68 383 2bbl motor that I pulled from a 68 coronet that has the holes drilled and tapped , I 2 have 69 HP 383's that were not in A bodies that are not machined, so the C body mount must have changed in 69 ?
Actually I believe it was only '65 C bodies that have this type of driver side mount, the first year of the newer body style. '66-on have the same brackets a B or E body would have. Why they would keep tapping these bosses after the run of BB A bodies I have no idea...maybe some truck app. parts might have used these holes?
Re: 383 ID please [Re: 440newport] #330439
06/01/09 02:28 AM
06/01/09 02:28 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
FWIW the 383 in my Challenger is drilled & tapped also, so it carried over to the 70 model year...
Re: 383 ID please [Re: 1_WILD_RT] #330440
06/01/09 11:30 AM
06/01/09 11:30 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What's the casting date on the block ? except for the one in my 69 dart all the 69 model year 383's i have , one 2 bbl motor that I sold to mark gates and the rest are 4bbl HP's that are not machined and tapped ??? One of the non machined blocks is now machined though , I did it so I could use it in the dart .
Re: 383 ID please [Re: RemCharger] #330441
06/01/09 03:09 PM
06/01/09 03:09 PM
NJ
Jeff_T Offline OP
super street
Jeff_T  Offline OP
super street
NJ
Do you know whats inside? I see you have head studs....
The only thing that original is the block. Its built be just streetable on pump gas. In a light Duster I should be happy!
The builder I bought it from is nearly a mopar expert and had no reason to sell the a-body issue to me. With all the crap that went on in the factories (Hemi four doors) to me its hard to say any motor can't be ruled out for any car based on common knowledge. Something out there on a true survivor car will always trump the experts status quo. It doesn't matter to me I just couldnt figure it out.
The builder also has a 6 pack motor he got out of a pickup truck. Transplanted with a 4bbl of course...
Jeff 1993 IROC R/T 1972 Barracuda
