Re: ramcharger cable
[Re: 6bblgt]
#329642
05/27/09 04:22 PM
05/27/09 04:22 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Dan,
So what you're saying is that it might be correct coming through that "dimpled" area too?
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#329643
05/27/09 11:36 PM
05/27/09 11:36 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
Dan,
Plymouth had a completely different N96 setup and used vacuum lines , the 70 dodge used the same ramcharger , except for the color of the under hood ductwork , as a 69 , they would have had to make a LONGER cable to move the routing of it and it would have added extra bends that may have hindered operation , i'd be completely surprised to see it coming out that hole on a 70 dodge .
[Re: JohnRR]
#329644
05/28/09 11:14 AM
05/28/09 11:14 AM
DPelletier
Thanks John, I'm going to run mine through the spot below the voltage reg. Ahhh the joys of buying a car I never took apart! Dave
1974 'Cuda
