Hard upper rad hose & bubbles in the Coolant #329074
05/26/09 12:14 PM
05/26/09 12:14 PM
Ft. Lauderdale, FL
solarguy Offline OP
solarguy  Offline OP
Ft. Lauderdale, FL
Any other reason (easy fix) other than a blown head gasket that would make the upper hose hard after about 15 minutes of running plus bubbling in the rad with the cap off? It looks like it's top end rebuild time.
Re: Hard upper rad hose & bubbles in the Coolant [Re: solarguy] #329075
05/26/09 02:08 PM
05/26/09 02:08 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
If it's constantly bubbling, it's say it's a HG leak.
BTW, you've heard Revell is reissuing the Tom Daniel Tijuana Taxi kit, right? I noticed it in your avatar...
Re: Hard upper rad hose & bubbles in the Coolant [Re: In_The_Pink] #329076
05/26/09 02:13 PM
05/26/09 02:13 PM
Ft. Lauderdale, FL
solarguy Offline OP
solarguy  Offline OP
Ft. Lauderdale, FL
[quote
No, I haven't heard. I'll check it out. Must've built a dozen of them as a kid. (common birthday present and fun to blow up and light on fire)
Re: Hard upper rad hose & bubbles in the Coolant [Re: solarguy] #329077
05/26/09 02:20 PM
05/26/09 02:20 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
is the thermostat open?
if so,and the system is under pressure its a h/g.
you can do a compression test to be sure.
also,if you have access to a smog sniffer it can detect exhaust elements in the rad too.
