Done all that. New hoses not NOS. Bled it so much I own stock in dot 5 brake fluid. I’ve thought about a pressure bleeder but all I’ve done is have a friend pump and hold method. It has never failed. My AAR does not bottom out. It stops like you hit a wall. Booster works fine three different MC. Rebuilt combo and metering valve, etc., etc.
Dot 5 can be a bit tricky in that it Aerates if moved to quickly when bleeding. if using the pump and hold method, Pump slowly or just depress the pedal somewhat slowly.
While holding the pedal down crack the bleeder slowly until the fluid starts coming out (slowly) Close the bleeder before the fluid stops moving. Repeat.
Even when using a pressure bleeder one has to bleed slowly.
You can also try gravity bleeding.
I wehn not using a pressure bleeder, I have occasionally needed re-bench bleed the master. reinstall on car. Have helper depress pedal while cracking open both front and rear lines going into the porp valve. Close before fluid stops. Repeat severa times. This prevents air in the front line from beiing sucked back into the master while bleeding at the rears. With DOT 5 SLOW is required
Pour some dot 5 in a small air brush jar, cap it and shake it
