Re: BRASS GEAR OIL DRIVE FOR ROLLER
[Re: A/MP]
#3282555
01/13/25 11:14 PM
01/13/25 11:14 PM
Posts: 2,766 Walton's Mountain, Pa
Steve1118
No. Just check it for slop every year, and when it gets too loose replace it. In 54 years I've replaced it three times.
"Old age and treachery trumps youth and enthusiasm, every time!" East Central Director / Chrysler Power Magazine www.reasbeckracing.webs.com
[Re: A/MP]
#3282572
01/14/25 01:08 AM
01/14/25 01:08 AM
Posts: 31,330 Oregon
AndyF
Does the the brass gear on the oil pump drive need to be a yearly serviced part(replaced) when used in a street/strip motor? Maybe. We see worn out gears all the time on drag race engines. At the minimum you should pull the distributor out every winter and look at the gear. If it looks fine then run it again, but once it starts to show wear you need to replace it. I'd never go more than two seasons without pulling the gear for an inspection.
[Re: A/MP]
#3282585
01/14/25 06:23 AM
01/14/25 06:23 AM
Posts: 44,135 Bend,OR USA
Cab_Burge
[Re: racerx]
#3282597
01/14/25 09:05 AM
01/14/25 09:05 AM
Posts: 9,207 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
A "melanized" steel gear may be a better choice workWhat about race only application? The bronze gears wore not only on the teeth but also on the bottom surface of the gear. So it needs to be pulled to check that - not just "slop" in the teeth. Anything that wears is going into the oil pan - and may find a new home along the way - or into the oil pump. In my "opinion", "minimal" wear is totally unacceptable. But when bronze was the only option with a billet cam . well, you know the rest. Melonized is a great leap forward HOWEVER, they're adamant that one should not be used on a cam that has already been using a bronze gear - in other words, to be used with a NEW cam only.
[Re: Stanton]
#3282607
01/14/25 10:14 AM
01/14/25 10:14 AM
Posts: 10,155 MI, usa
dvw
MI, usa
A "melanized" steel gear may be a better choice workWhat about race only application? The bronze gears wore not only on the teeth but also on the bottom surface of the gear. So it needs to be pulled to check that - not just "slop" in the teeth. Anything that wears is going into the oil pan - and may find a new home along the way - or into the oil pump. In my "opinion", "minimal" wear is totally unacceptable. But when bronze was the only option with a billet cam . well, you know the rest. Melonized is a great leap forward HOWEVER, they're adamant that one should not be used on a cam that has already been using a bronze gear - in other words, to be used with a NEW cam only. Mine has the bottom of the gear slightly trimmed. It runs a hardened washer from a Torrington between the gear and the bushing. The bearings always look good on inspection. The bushed roller lifters have even in the motor for over 750 runs (320/830 pressure). Can’t detect any wear issues caused by the bronze particles. Doug
[Re: second 70]
#3282658
01/14/25 02:56 PM
01/14/25 02:56 PM
Posts: 1,479 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Despite the warnings, I've heard of at least one person on this board who switched from a bronze gear to a melonized gear after the engine had some miles on it. Last I recall, they saw no wear issues when checked later.
In my case I swapped 'em out after the new engine's dyno session. I hated the idea of the bronze getting spread all through the engine over time, even though a lot of foiks say their wear issues are "reasonable". From what little street use I've driven since, it looks fine, FWIW.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3282659
01/14/25 03:02 PM
01/14/25 03:02 PM
Posts: 4,248 Canada
Kam*Kuda
Canada
I had a lot more gear wear with 20w50 vs 10w30
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: Kam*Kuda]
#3282663
01/14/25 03:25 PM
01/14/25 03:25 PM
Cab_Burge
I'm thinking the soft brass gear is sacrificial in the high RPM, high valve spring pressure, drag race world, maybe not :work I have had some brass gears wear and some that didn't, me thinks AndyF is correct on his thinking on stock Mopar blocks variance on finish machine
