For Sale/ Wanted - Big Block Engine - 1st Quarter
#3279402
12/31/24 06:56 PM
12/31/24 06:56 PM
Posts: 15,673 Norwich CT USA
moparts
Norwich CT USA
Re: For Sale/ Wanted - Big Block Engine - 1st Quarter
[Re: moparts]
#3279568
01/01/25 10:36 AM
01/01/25 10:36 AM
Posts: 5,813 Detroit area
6PAX
Detroit area
70 B-body voltage regulator mounting bracket. $15
New chrome coil cover & coil mounting bracket. $20
New factory type big block spark plug wire separator kit. Some surface rust from humidity on a couple of them. $50
NOS big block heat riser kit #3420046. $225
NOS Cal Custom chrome radiator cap. $20
NOS Cal Custom chrome battery hold down. $25
Four new extra wide chrome valve cover hold down clamps. $10 for the set
NOS Cal Custom polished big block valve covers. $450
New exhaust manifold heat stove to air cleaner hose. $20
NOS fan clutch 3769614 for 1974 all V-8 engines. $100
New big block chrome valley pan hold down rails & bolts. $30
Gauge type oil pressure sending unit. $20
Vintage Cal Custom 14" finned aluminum air cleaner with filter. $100
New Mopar Performance chrome big block distributor hold down. $20
New Mopar Performance chrome water neck. Was bolted on an engine but then taken back off before the engine was ran. $10
NOS Direct Connection big block double roller timing chain #P4120264. $75
New Mr. Gasket chrome oil filter cover. $15
MP big block high volume oil pump P4286590. This was new when I tried it on my motor but it was too much pressure so I switched to a stock pump. $80
9 Chrome t-handle valve cover bolts. $10
Factory starter, part/casting #3755259. This came off of my Dart about 10 years ago. Worked fine then, been sitting on a shelf ever since. $40
NOS Cal Custom chrome dagger dipstick handle. $25
Mopar Performance 5 blade radiator fan and clutch. $100
1972 400 spark plug shields $10 pair
Factory warning light type oil pressure sending unit. $10
Chrome big block timing tab. $5
Chrome single groove alternator pulley. $15
New Mopar Performance big block 8 qt. oil pan with new pick-up. $200
1971 Charger big block throttle cable. $40
New AR Engineering big block lightweight alternator kit with 60 amp Denso alternator. I mounted this on my engine on the stand but ended up using a factory alternator. $175
Original 2 piece heat stove from 1970 440 exhaust manifold. Good condition. $125
1975 Date coded alternator. Part #3874271. $25
Pioneer Automotive cylinder head dowel pins. 21 pieces 1/4" x 5/8". $10
1967 4bbl intake manifold part# 2806178. Sandblasted and primed. $100
Rev-n-nator Coil and programmable ICU. $200
Vintage Cal Custom scoop style air cleaner. Very nice condition. Includes often missing matching wingnut. $300
New in boxes QTP 2 1/2" electric exhaust cutouts #QTEC50, stainless y-pipes #10250 and remote controller #10900. $654 total price at Summit. $500
Prices do not include shipping.
gt340 @ yahoo.com
[Re: budman1965]
#3280064
01/02/25 07:46 PM
01/02/25 07:46 PM
Posts: 2,820 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I'm wanting a 4500 M1 intake for a low block. If you can help me out with one of these let me know, thanks. Rick Seeman 501-519-742five
2011 Drag Pak Challenger
[Re: moparts]
#3280086
01/02/25 08:42 PM
01/02/25 08:42 PM
6PAX
Detroit area
Howard's solid flat tappet cam for Mopar big blocks, part number CL722322-08. See links below for specifications. I bought this cam for my engine with the intention of taking the car to the track when the car was finished being restored along with the engine being built but I have changed my mind about racing the car and decided to go with a milder hydraulic cam instead. I had this cam installed in my engine on the engine stand but it never was run and is essentially new. $375 + shipping. I also have a new set of Comp Cams 973-16 inner valve springs I was going to use with this cam and Edelbrock RPM heads that I am asking $40 for. https://www.summitracing.com/parts/HRS-CL722322-08https://www.summitracing.com/parts/cca-973-16gt340 at yahoo.com
Re: Wanted - Big Block Engine - 1st Quarter
[Re: dsd70bee]
#3281881
01/10/25 02:05 PM
01/10/25 02:05 PM
Posts: 44,129 Bend,OR USA
Cab_Burge
I need and want to buy a stock AVS intake and carb for a 1970 375 HP 440 manifold, casting date from 04-1968 to 10-1968. I need a stock single or dual point distributor also if you have one. PM me on here or E mail me at cabburge@wans.net, let me know your price with the shipping to me in zip code 97702 which is Bend, OR Thanks: Cab
Throttle cable brkt
[Re: moparts]
#3281901
01/10/25 03:06 PM
01/10/25 03:06 PM
Posts: 846 In the Middle
roadntrack
In the Middle
Throttle cable bracket for auto trans Came off a 1969 440 $40 plus shipping PM me for info please
Remember when cars were FUN?
Alt brkt
[Re: Cab_Burge]
#3281902
01/10/25 03:09 PM
01/10/25 03:09 PM
roadntrack
In the Middle
Alternator bracket from a 1969 440 $20 plus ship PM me for info please
HOLLEY 37-921
[Re: moparts]
#3281944
01/10/25 05:29 PM
01/10/25 05:29 PM
roadntrack
In the Middle
HOLLEY Trick Kit 37-921 It has been opened, not sure if anything is missing as this kit seems to be no longer available $45 plus shipping PM me for info please
HOLLEY 3-396
[Re: moparts]
#3281946
01/10/25 05:50 PM
01/10/25 05:50 PM
roadntrack
In the Middle
HOLLEY 3-396 gasket pkg for HOLLEY 2300 2bbl It has been opened. Not sure what is missing as the kit seems to be discontinued $20 plus shipping PM me for info please
P4007671 6bbl tune kit
[Re: roadntrack]
#3281960
01/10/25 06:38 PM
01/10/25 06:38 PM
roadntrack
In the Middle
DIRECT CONNECTION MOPAR PERFORMANCE P4007671 Tuning pkg for 1969 440-6bbl $185 plus shipping PM me for info please
water pump housing
[Re: moparts]
#3281969
01/10/25 07:14 PM
01/10/25 07:14 PM
roadntrack
In the Middle
High flow Water pump housing from a 440 motorhome. casting 3751216 $50 plus shipping PM me for info please
Meter plates
[Re: roadntrack]
#3281975
01/10/25 07:41 PM
01/10/25 07:41 PM
roadntrack
In the Middle
Holley metering plates from 1970 440-6bbl Stamped 34 and 35 $90 PM me please
